Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
Posted: Thu Mar 13, 2014 8:40 pm
Ive just put new shoes in the rear, released adjusters as normal to fit the drums on.
Apon test driving the rear brakes were holding on, could smell them and it lacked power. I got home and jacked up the rear and only the right was holding on but enough to spin the wheel by hand. Ive also disconnected the spring from diff to proportion valve as ive lifted the rear a fair bit.
2 things, either the spring needs to be on so both brakes receive the same braking force or The new shoes could take a while to free up?
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
Posted: Fri Mar 14, 2014 2:53 pm
theres a gap you can fit a screwdriver through to turn the cog to loosen it off. very easy while you have the drum off. pump the peddel 20-30 times to tension it to the correct ammount after backing it off if you want any rear breaks
Users browsing this forum: No registered users and 502 guests
