It is currently Thu Oct 29, 2026 12:21 am
Vehicle: 1996 swb Vitara Soft top
Post Posted: Wed Mar 19, 2014 10:04 pm
Intend to replace water pump on my 1996 EFI 16V Vitara (Pump has been been rattly for a while now)
Want to know if I have to remove & replace Timing Belt at the same time or can I just replace the water pump without having to pull timing cover & replace belt etc
Also intending to replace radiator at same time so should it be necessary to remove timing cover etc I would then consider replacing timing belt etc.
Thanks
Dusty
Vehicle: Sj51t
Post Posted: Wed Mar 19, 2014 10:12 pm
best to do timing belt at same time as you have to pull cover ect off, so might as well do it at the same time.
not a hard job to replace both then its done for 100,000kms :D
Post Posted: Thu Mar 20, 2014 7:45 am
the timing belt tensioner bolts to the water pump so yep you have to pull it all off, its not a big job though if you are familiar with timing belts
consider replacing the cam and crank seals while you are there
Post Posted: Fri Mar 21, 2014 12:05 pm
Do the radiator as well - makes it easier to get your hands in if it's gone.
Post Posted: Fri Mar 21, 2014 8:24 pm
Still gotta pull all the existing stuff off/out, and once done it's all a 100,000km set and forget.
Post Posted: Fri Mar 21, 2014 9:05 pm
Thanks fellas,contacted Greg at 4wd Products & bought water pump timing belt kit,new radiator, set new hoses & thermo clutch fan.
Easy to deal with & great advice/prices.--now to put it all in!!
Thanks for all your advice.
Dusty
Users browsing this forum: No registered users and 567 guests
