It is currently Thu Oct 29, 2026 12:24 am
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Wed Mar 26, 2014 3:52 pm
what about the stronger front axles thing
the crappy chain driven transfer
the piston skirts that decided to part ways with the piston
the weak diff material that loves to tear holes in it
this is just for starters, the hate for coilys is for the fact that they are half assed.
Post Posted: Wed Mar 26, 2014 4:53 pm
Surely there's ways to do the front locker in a coily. Couldn't you put the coily radius arm mounts on a WT housing? Or use NT (cheaper) centre housing with coily axle tubes? Lots of effort but that's the price of being different right?
Vehicle: LJ80 Stockman Tin Top
Post Posted: Wed Mar 26, 2014 5:47 pm
Got CTP sorted and Drove the LJ80 down to the Safety Certificate place.
The pictures are kinda crappy as it was low light but you get the idea.
The paint job is pretty average. Lots of runs but looks ok from a couple of meters.
The specks are reflections of the flash. the upholstery is A1.
Should there be something here where these 2 holes are?
Nicko
Vehicle: Which one?
Post Posted: Wed Mar 26, 2014 5:50 pm
Ahh, so you are the one that finally bought that thing. It's been in my watchlist for an age!
Post Posted: Wed Mar 26, 2014 5:55 pm
So it's a Stockman, has the 26 spline axles in it's rear end, that's a good thing. Body work looks good from this far back. Little bit better brakes than a regular LJ80 too.
Vehicle: WT sierra, GU CRD
Post Posted: Wed Mar 26, 2014 6:00 pm
Looks great.
I want one too now. (actually I did before :lol: )
I love ZD30. :)
Post Posted: Wed Mar 26, 2014 6:02 pm
from those pics it looks mint condition, especially for a hardtop LJ!
Post Posted: Wed Mar 26, 2014 6:11 pm
Hi 3cyl - What makes it a stockman? and what are the differences?
Brakes were pretty average. I drive the Chevy Luv parked next to it as a daily and the 4 wheel drums on that thing stop on a dime compared to the LJ.
Post Posted: Wed Mar 26, 2014 6:29 pm
Should be some searching you can do but the Stockman has a plastic dash, funny looking grille, (long standing joke on here) bigger unis, bigger rear axles, wheel bearings, more switches on the column instead of the dash, bigger brakes. When working ok the brakes should work about the same as the ones on that nice chev Luv. Could be adjustment or seized wheel cylinder/s, remember there's no booster so you'll have to push the pedal a bit.
Post Posted: Wed Mar 26, 2014 6:33 pm
Cool. Thanks for the info.
I will have a play with the brakes tomorrow arvo. They dont feel broken. Just uninspiring. Like maybe shoes adjusted off center so that only portions of the linings contact the drum.
No Booster in the Luv either :D
Vehicle: lj81
Post Posted: Wed Mar 26, 2014 7:05 pm
Nice lj mate. Dont spend any money on these brakes, not worth it for brakes that you have to adjust all the time. Highwaystars sierra brake upgrade is the way to go, and freewheeling hubs too.
Post Posted: Wed Mar 26, 2014 7:17 pm
From memory the big nut on the front (holding the drum onto the CV shaft) is 36mm. Most of us have Sierra discs and free wheeling hubs now days so not 100% sure.
Post Posted: Wed Mar 26, 2014 7:34 pm
The same size as a rear axle nut on a Volkswagen type 1. Just so happens Ive got one!
Post Posted: Wed Mar 26, 2014 7:55 pm
Haha, we have old VWs here too, that's why I had one already.
Vehicle: 95 sj70 and 78 lj81
Post Posted: Wed Mar 26, 2014 8:16 pm
great choice, by the way all LJ's look good from a distance ha ha
Post Posted: Wed Mar 26, 2014 10:06 pm
The bonnet holes are because it used to have a Mack truck dog on there.
That thing's been for sale forever, glad to see someone bought it. Carpeted interior is awesome. 8) That's super clean for an LJ.
Vehicle: Suzuki Sierra 1996 Coily
Post Posted: Thu Mar 27, 2014 12:22 am
So many poeple with a WT puts 1 ltr transfer cases and low range gear and the work to change it is minor as it is a stand alone case
Not sure what you are on about but these engines are very similar if not the same but if you are going to do an engine conversion like most this is irrelevant (if this is not what you are talking about plz explain)
If you are putting holes in diffs you are doing something stupid, competitions or haven't got diff breathers
In general If you ask people the hate for coilys seem to be very misplaced
Post Posted: Thu Mar 27, 2014 5:20 am
Putting plastic bushes in the radius arms can cause the brackets to tear off the housing because the plastic doesn't flex as much as rubber
Post Posted: Thu Mar 27, 2014 7:01 am
Seems like as a coily driver you should read more about them.
Post Posted: Thu Mar 27, 2014 7:38 am
Hahaha I thought EXACTLY the same thing when I read it, haha.
Post Posted: Thu Mar 27, 2014 8:53 am
I have done research and I have seen that most people that have snapped them have hit something way to hard like a big ditch in the road at 70km/h
Post Posted: Thu Mar 27, 2014 9:18 am
nope, its caused by flexing at low speed, ive heard of rubber bushes causing it too but poly ones do it worse.
the weak axle tubes flex back and forward and tear.
the engines are not the same as a leaf one, similar but a different engine number, and the piston skirts do tend to snap
Post Posted: Thu Mar 27, 2014 9:30 am
most leaf sierras were g13a, after that they went to g13ba.
Post Posted: Thu Mar 27, 2014 10:32 am
Early leaf sierras were g13a, after that they went to g13ba.
There was a design flaw or fault when it came to the coily G13ba's. Pistons cracking skirts are a pretty common occurrence
Post Posted: Thu Mar 27, 2014 10:33 am
Oh come on JR, why such hate for the coily.
Post Posted: Thu Mar 27, 2014 10:37 am
What Tanshi said, coil front end Landbruisers do it too, radius arm suspension is designed NOT to articulate.
Post Posted: Thu Mar 27, 2014 8:35 pm
Registered and on the road.
Also added the AZ Sticker that arrived today.
I have started a thread for the car in the Rigs forum.
viewtopic.php?f=4&t=45624
Nicko
Post Posted: Thu Mar 27, 2014 10:25 pm
So what you telling me is that every coil sprung patrol, landcruiser, jeep and many other models that are used as extreme 4x4 dives aren't designed to flex????
Post Posted: Thu Mar 27, 2014 10:57 pm
This is gunna get good. 8)
Compare patrol, LC etc to the Rangie Radius arm setup.
Considering we're bringing un related models into it....
I love ZD30. :)
Post Posted: Thu Mar 27, 2014 11:23 pm
So compare then
Users browsing this forum: No registered users and 641 guests
