It is currently Fri Oct 30, 2026 6:26 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2
Post Posted: Thu Mar 27, 2014 9:49 am
honour wrote:
Can I just say - I was involved in the import car scene for many years, and part of many forums, but never have I met a more helpful bunch of people. So thank you guys so much for that, I really appreciate it.
The KM2's sound good, Alien. Will be looking more into that.
Was also thinking - I might put on the 235's and the new wheels temporarily just to see how much scrubbing etc I'll be up for, and see how that goes.
Also - are 225's a decent option?
you get helpful out of us if you ask the right questions , in the right way and take the advice that people give.
If you were asking about putting lux diffs and a holden v6 in it you probably wouldnt get the same response.
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 12:27 pm
Hahaha.
Post Posted: Thu Mar 27, 2014 12:33 pm
Just checked my pricing book the KM2's in the muddy rrp $319 each.
Dave
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 12:44 pm
So I decided to try on the wheels and tyres I have, merely in order to learn for myself where the scrubbing points etc are, therefore what needs to be trimmed etc.
So what I have fitted is a set of 15x7's (i think), with a pair of Kuhmo 235 75 15's on the front, and 31's on the back.
Surprisingly, the gearing didn't seem all that bad to me (although instantly noticeable, and I have only tried high gearing so far), and normal driving on road seemed fine. No noise or scrubbing at all. However a definite oversteer was present, obviously aided by the difference in tyre size front to rear.
I did take it shortly off road, and that was where the scrubbing started, both front and rear. By the look of it, the standard trimming of the front bumper and perhaps the guards should fix up the front, however a downsize from the huge 31's on the back will be required.
But all in all - a great day of learning!
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 12:45 pm
Thanks heaps bohuler - will definitely keep that in consideration. A friend of mine owns the tyre shop in Coober Pedy, so will see what he can do for me.
Thanks again mate!
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 1:05 pm
This is with the 235 fronts and 31 rears.
Before this, I really was set on going pretty big.
Now I think I've realised that smaller may indeed be better for me, and the 215 option suggested is looking pretty good.
Vehicle: Sj51t
Post Posted: Thu Mar 27, 2014 1:39 pm
that's my jimny on 31s only 2inch lift with a chop and trim
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 1:45 pm
That looks great Sookie!
Gearing?
Also, how do you find it on sand?
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 5:22 pm
Had a little more of a play tonight just on my property, and wow the difference!
Gearing doesn't actually seem too bad in low (as in a don't have to ride the clutch to crawl).
There are a couple of little (I mean LITTLE) hills on my property that were a challenge with standard tyres. The one pictured below I have never actually made it up in standard form - I know it looks tiny in the photo, but it is quite steep and soft close to the vertical wall.
With the new tyres, no problem. Straight up, no loss of traction. Was almost boring. Haha.
So now I might swing back to 235's.... Haha. Sorry guys! It's all just too much fun!
Post Posted: Thu Mar 27, 2014 6:09 pm
Prolly more due to the aggressive tread than the size of the tyre... plus if you did it at the same RPM with 31's fitted that you did with 205's fitted you'd be going about 20% faster =)
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 7:15 pm
Very true, Alien. I was unsure of diff clearance as well as flex scrubbing (as I am very new to this) so took it all very very slow, hopping out where I could to see how everything was reacting. Today really has been a great learning curve in regards to how everything operates in use, and I certainly feel a lot more familiar with the smaller characteristics of the vehicle.
Post Posted: Thu Mar 27, 2014 10:29 pm
give it another crack with the small tyres, and go a bit faster... (20% if you can figure it out) - i'll bet it drives up just the same as with the bigger tyres.
Vehicle: 2002 Jimny
Post Posted: Thu Mar 27, 2014 11:41 pm
Will be pulling these back off tomorrow to reassess, so will definitely try hitting it again with the stockies. Thanks heaps Alien!
Post Posted: Fri Mar 28, 2014 6:43 am
When you were in 4 low you didn't have the front hubs locked in did you?
With two different sized tyres on the axles the transfer case is going to be getting a lot of bind up because the rear axle is trying to drive further than the front with every revolution.
Vehicle: 2002 Jimny
Post Posted: Fri Mar 28, 2014 8:38 am
I was a little worried about that, and wasn't sure if it was going to put a lot more strain on drive components. No, not locked. (To be honest, I didn't know I could lock them)
Post Posted: Fri Mar 28, 2014 9:20 am
having you a 2002 jimmy it would be heaps easier to get a transfer case gearing than for a newer model jimmy. And if you are able to do the job yourself the parts are not really that expensive. You only need the swap kit from ORA, and to find a WT -tcase in good nick,... or restore an ok one
from memory of what I was looking for, with a sierra wt t-case swap you will be almost spot on on 235's on high, but your low would be more similar to running 215's on stock jimmy case.
if you get 4.9 gears on it, the high would be bit over geared. (easier to drive but more revvy.... just don't remember if it was with 235's or 30's that worked best)... and of course low gear would be loooooooooooooooooow
Vehicle: 2002 Jimny
Post Posted: Fri Mar 28, 2014 12:23 pm
Ok great! Although I do most work on my cars myself, I think I'd leave a transfer case swap to a professional - just don't want to risk it.
How much should I be paying for a WT case normally? I am considering going to 235's for now, and then once I start finding more time to get out wheeling (and of course save some funds), then I will do the transfer case.
Vehicle: 2002 Jimny
Post Posted: Fri Mar 28, 2014 6:40 pm
Focusing on the wheels instead of the tyres for a second - black or white?
Vehicle: 2005 Suzuki Jimny JLX
Post Posted: Fri Mar 28, 2014 7:11 pm
BLACK!!!!!
Post Posted: Fri Mar 28, 2014 8:22 pm
Black for sure.
Although Gold would look pretty sweet =P
Vehicle: WT sierra, GU CRD
Post Posted: Fri Mar 28, 2014 8:26 pm
Gold.
I love ZD30. :)
Vehicle: 2002 Jimny
Post Posted: Fri Mar 28, 2014 10:07 pm
Gold. Whoa! Didn't even think of that.. Hmm... will have to consider that one.... Or maybe even a gunmetal? Although the plan was to originally have pretty well everything black, even spray the red surrounds of the driving lights to black. Haha.
Vehicle: 2002 Jimny
Post Posted: Fri Mar 28, 2014 10:27 pm
Gold you say? (sorry about the terrible Photoshop)
Post Posted: Sat Mar 29, 2014 12:18 am
Yep. Gold.
Vehicle: 2002 Jimny
Post Posted: Sat Mar 29, 2014 9:01 am
Here's a really interesting little calculator I found for comparing tyre sizes
http://www.tacomaworld.com/forum/tireca ... -235-75r15
Post Posted: Sat Mar 29, 2014 12:32 pm
Vehicle: 2002 Jimny
Post Posted: Sat Mar 29, 2014 2:25 pm
Lol!!!!!!!!!!!!!!!!!!!
Post Posted: Sat Mar 29, 2014 4:09 pm
Black. Always black.
Vehicle: 2002 Jimny
Post Posted: Sat Mar 29, 2014 5:46 pm
Haha. Well I'm leaning toward black with 235 Bighorns. Thoughts?
Users browsing this forum: No registered users and 395 guests
