It is currently Fri Oct 30, 2026 7:28 pm
Post Posted: Tue Apr 08, 2014 4:22 pm
are g16b engine able to have a 3mm bore increase or will that sacrifice its overall integrity too much?
Im just interested as in the old days suzisport advertised 1750cc piston kits which now dissapeared.
3mm oversize will give 1720cc
Post Posted: Tue Apr 08, 2014 6:16 pm
perhaps they were using dished pistons also? (EFI g16 has dished and i believe carby doesn't?)
Post Posted: Tue Apr 08, 2014 9:43 pm
Piston crown dimensions will not alter the swept volume.
3mm over is a fair wack! I have no idea how thick the liners in them are.
Vehicle: sj51
Post Posted: Tue Apr 08, 2014 10:17 pm
shorter rods?
Post Posted: Tue Apr 08, 2014 10:57 pm
Rod length also will not make any difference in the capacity as the stroke is determined by the crank throw and the rod just relays that.
Vehicle: Which one?
Post Posted: Wed Apr 09, 2014 6:59 am
Yep. A common misconception. I think it's because so many "stroker kits" come with new rods and humans have a tendency to make up their own links between causation and correlation: "Increased engine capacity needed new rods, therefore new rods increase engine capacity.", or something like that.
Post Posted: Wed Apr 09, 2014 10:50 am
At 3mm there would be no gasket left between the cylinders when my motor bloke looked in to it
Vehicle: 85 ' Drover
Post Posted: Wed Apr 09, 2014 11:00 am
Only some of them:P
What is the biggest oversize piston you can buy from a reputable piston manufacturer? That's how big i would be goin...
Post Posted: Wed Apr 09, 2014 12:38 pm
I went 30 thou
Post Posted: Wed Apr 09, 2014 6:20 pm
78mm mazda pistons and a custom head gasket from ACL . The little end of the rod needs to be reamed out to 20mm ..
Post Posted: Wed Apr 09, 2014 6:33 pm
haha d , its n0madic from redline , thought i seen questions about the apv engine etc in 2 places...
Vehicle: sj51
Post Posted: Wed Apr 09, 2014 8:18 pm
hi, my name is pezz.. im from amature hour.... next time i will think before i type.. 8O i should know better than this
anyhow, off to crawl into a hole now... i feel dumb
Post Posted: Thu Apr 10, 2014 1:36 pm
can you share more about the pistons or results? I know the head gasket is 77mm so did you make a new one and impression or opinons on this setup?
Heya D Man, thought I was repeating myself or hearing my own echo! :) few G16 fans in this little world maybe more here than there
Users browsing this forum: No registered users and 324 guests
