| Author |
Message |
JuniorJoel
Vehicle: 2000 model Suzuki Jimny
 Posted: Sun Dec 15, 2013 10:19 am |
So guys,
I know this is probably a random question but i was wondering if anyone knew of anyone that produces a "Mini spool" for a Suzuki jimmy. Im just after one for the type of driving I'm doing and would prefer a constantly locked rear than an auto locker as I'm not really into the whole "locking-unlocking" thing. Just after a constant locked rear.
So if anyone could help me out would be much appreciated.
Thanks, Joel
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Sun Dec 15, 2013 10:26 am |
A Sierra mini spool will fit. A Jimny uses the same rear diff centre as a Sierra. Don't get a Trail Gear one, they're weak. Trail Tough is the one to get I believe.
FWIW I've got a pretty well setup auto locker and aside from the extra play it creates I have no issues with it at all.
Blkfxx
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
 Posted: Sun Dec 15, 2013 11:46 am |
sideways wrote: Don't get a Trail Gear one, they're weak. Trail Tough is the one to get I believe.
Gwagensteve wrote: Just order one from Trail Tough.
DO NOT order one from Lowrange Offroad, they're the trail gear ones that break into 7 pieces.
Steve. Gwagensteve wrote: Trail gear have theirs marked "aged cheddar" because that's how strong they are.
Trail tough's are marked "trail tough" because they are.
PS - to provide some facts, search the photos of them. TG's are much more cheaply made and weren't/arent, as far as I am aware, heat treated. Yep, Trail tough is the one to get.
_________________ Quote: I like the tuna here
JuniorJoel
 Posted: Sun Dec 15, 2013 3:45 pm |
Okay perfect. Thanks for the help. One more question though, is the sierra known as the "sidekick" over in America? And is there any year model sierra I should be aiming for or are they all the same centre?
Thanks again for the help, It is much appreciated
sideways
 Posted: Sun Dec 15, 2013 4:06 pm |
Sidekick is a Vitara. Sierra is a Samurai. Buy one of these. http://www.trailtough.com/index.php?pag ... &Itemid=531l Sierra diffs are different but APIO is the only mob who makes mini spools for them so you need some amazingly bad luck to accidentally buy one of those.
JuniorJoel
 Posted: Fri May 02, 2014 8:20 pm |
Just want to check that a sierra mini spool will Infact fit a jimny rear diff. I'm about to order one finally and just thought I should double check.
Thanks, Joel
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Fri May 02, 2014 8:47 pm |
I know jimny 4.1 rears are weak as p iss even unlocked Maybe rethink the spool concept i have sold 4 lwb sierra centers to replace jimny rears in the last couple years as they seem to be made a little better
Marko_SJ
Joined: Tue Jan 17, 2012 1:40 am Posts: 2979 Location: Darwin, NT
Vehicle: WT sierra, GU CRD
 Posted: Fri May 02, 2014 8:55 pm |
sideways wrote: A Sierra mini spool will fit. A Jimny uses the same rear diff centre as a Sierra. Don't get a Trail Gear one, they're weak. Trail Tough is the one to get I believe.
FWIW I've got a pretty well setup auto locker and aside from the extra play it creates I have no issues with it at all. I advocate an auto locker over a minispool. I've never driven a minispool, but when my locker was new it would sometimes not unlock and feel like how a spool would be on road. Yuck! Just my opinion however.
_________________ I love ZD30. :)
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13014 Location: Melbourne
 Posted: Fri May 02, 2014 9:40 pm |
There's nothing wrong with a spooled diff. 100% predictable. I've driven on an auto locker and would much rather drive a spool than an auto locker. Just my opinion.
Marko_SJ
 Posted: Fri May 02, 2014 10:26 pm |
Gwagensteve wrote: There's nothing wrong with a spooled diff. 100% predictable. I've driven on an auto locker and would much rather drive a spool than an auto locker. Just my opinion.
Steve. Did you daily drive it Steve? I assume because its a Jimny its not a dedicated off road rig. Hence there might be an element of daily driving. Having the tires skip every tight corner seems like an expensive way to daily drive to me, and a PITA in car parks. I'm glad there's a choice in between (price wise) a spool and an air locker. Just my opinion
mnemonix
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1409 Location: Newcastle NSW
Vehicle: '96 LWB trayback
 Posted: Fri May 02, 2014 10:56 pm |
I'd take my old minispool over the lockrite any day of the week. Even daily driving. If tyre pressures are correct, it's barely noticeable onroad.
I managed to perform the "exploding trail-gear trick" and create the 7 piece spool - definitely go with a trail tough. Sierra one definitely fits a jimny rear.
_________________ Twin charged twin cam twin locked webwheeler
Marko_SJ
 Posted: Fri May 02, 2014 11:23 pm |
mnemonix wrote: I'd take my old minispool over the lockrite any day of the week. Even daily driving. If tyre pressures are correct, it's barely noticeable onroad.
I managed to perform the "exploding trail-gear trick" and create the 7 piece spool - definitely go with a trail tough. Sierra one definitely fits a jimny rear. I guess it comes down to preference then. I honestly can't fault the auto locker off road. Road it is bearable IMO, and I spend a reasonable amount of time in the car each day. I can honestly say I almost stuffed the spider gears back in there a few times in the first two months though.
3cyl
Joined: Tue Jan 29, 2008 10:30 pm Posts: 2054 Location: Ipswich
 Posted: Sat May 03, 2014 6:16 am |
I've been running a welded rear for years now, not by choice I can tell you. The car's no daily and even then it's not so good, not a problem at speed but around slow streets and car parks it's all bind, chirp skip. Flogs out suspension bushes, transfer mounts, twists axles. The Lockrights it replaced (broke 2) were pretty funky but I preferred them. Hope to finish putting in the air lockers and test drive it today, expecting these to be better. IMO if you're going spooled rear just get an old Sierra diff and remove the side gears, weld the voids between the teeth, as in fill 2 leave 2 then put them in the rear and see for yourself if you like it, at least if it sucks as bad as I say it hasn't cost anything and you can spend the money you save on a Lockright or China/ Airlocker. Wasn't Joeblow creating something?
russty_2008
Joined: Thu Nov 26, 2009 10:30 pm Posts: 435 Location: Gladstone QLD
Vehicle: G16b 83
 Posted: Wed Jul 09, 2014 5:31 am |
I have a 99 jimny with a g13 bob will a Sierra mini spool fit it just wanting to triple check before I order one
russty_2008
Vehicle: G16b 83
 Posted: Wed Jul 09, 2014 5:33 am |
And by bob I mean bb ha ha
russty_2008
Vehicle: G16b 83
 Posted: Wed Jul 09, 2014 5:36 am |
Gwagensteve
 Posted: Wed Jul 09, 2014 6:54 am |
Surely you're not serious? It's already been answered countless times in this thread and many others.
