It is currently Wed Oct 21, 2026 9:32 am
Post Posted: Fri Aug 28, 2009 6:31 pm
Which is the best transfer case for crawling? I have a 1l and a 1.3l. I notice that a lot of sierras are advertised with a 1l case.
Post Posted: Fri Aug 28, 2009 6:50 pm
a 1ltr case is 12% lower then a 1.3 case.
Post Posted: Fri Aug 28, 2009 6:54 pm
yeah i thought that 1L were 5%
Post Posted: Fri Aug 28, 2009 6:56 pm
nope. there is 5% diferance between 1.3 wt and nt diff ratio's :wink:
Post Posted: Fri Aug 28, 2009 8:37 pm
oh very noice... ill add that to my collection of stuff i know... cheers
Post Posted: Sat Aug 29, 2009 9:25 pm
I would love to add one of those transfer cases to my collection :)
Forget the 5% ? Just get reduction gears !
Question ? Do you have to get a 1 litre transfer machined , like the
1.3 ? To fit in reduction gears . If not I'll take the 1 litre ;)
But seriously if yourve got the cash gears!!!!
Vehicle: Clown Car..
Post Posted: Sun Aug 30, 2009 12:51 am
ok 1 litre xfer is the alternative(cheap) way of goin about gears rather than spending big on aftermarket gears.There are two types of cases.. one with a switch and one without... Aftermarket gears WILL NOT fit into a 1litre xfer if it does not have a shift switch..only a 1.3(and not a coily case) even still machining MAY neede to be done...
The swap(1.3-1litre) is pretty stragiht forward, just a matter of possibly changing a mounting arm and swapping over the flanges/uni to what works. (There is a slight difference between the WT and the NT uni hence the need to swap.)
(im open to correction if there is anyone who disagree's or knows otherwise, personally if I was contemplating this, id go diff gears over xfer)
correction done :) ta shep :D
Post Posted: Sun Aug 30, 2009 1:03 am
trans gears will fit in a 1ltr case as long as it has the 4x4 switch.
Post Posted: Sun Aug 30, 2009 6:28 pm
what do you mean by switch
Post Posted: Sun Aug 30, 2009 6:29 pm
if it has wires hanging out of the box it is the right one.
Post Posted: Sun Aug 30, 2009 6:30 pm
i got them they go to my light
Users browsing this forum: No registered users and 112 guests
