It is currently Wed Oct 28, 2026 12:36 am
Vehicle: Suzuki Jimny
Post Posted: Wed Dec 14, 2011 2:13 am
:helloo: plans I bought a lj80v and sj50 the sj's body just smashed but the chassis had brand new king springs and extended shackles and a drop down tank rockcrawler transfer and tonnes more. Then theirs the lj well the lj's body is in pretty good condiction put some idiot put a diesel that was a really bad fit and the springs look like they were out off a f truck. so the plan is to do a body swap sj chassis and lj body and sj engine,gearbox,transfer,diff, fueltank. So if any one has any ideas for while I'm building thanks. And il keep u guy informed while it happens :cheers:
Any 4wding
Post Posted: Wed Dec 14, 2011 2:16 am
drop tank in a sierra 8O
They're too low/in the way as it is!
Post Posted: Wed Dec 14, 2011 2:33 am
What are you wanting to do with this thing when you're done?
You might be better off keeping the LJ in one piece and pissing off the diesel.
I can just imagine what the LJ crew will say about you putting a good condition LJ body onto a Sierra chassis :lol: :lol: :lol:
Post Posted: Wed Dec 14, 2011 2:45 am
it wont be complimentary, and very likely include much colourful and descriptive language.
personally, I would try and put the LJ back to how it should be.
stephen.
Post Posted: Wed Dec 14, 2011 4:43 am
Littlejeep is part the way into putting an LJ ute cab onto a 1L Sierra chassis. I can understand why he is doing it (his LJ81 chassis was rusty, and he wants a large tray area). However I think everything about the Sierra chassis is worse for a 4wd, and questionably better for much else..... A SWB LJ will also be significantly shorter than a SWB Sierra chassis, I think it will end up a bit of an ugly duckling unless you are awesome at panel work (stretching it).
All the Sierra springs will fit on the LJ if you prefer them. You can even make a Sierra transfer fit into the LJ with some work if you want the crawler gears. And hell, you could even fit the SIerra's engine and 5speed box to the LJ; it might sound like allot of work, but I reckon no more work than making the tub fit the chassis, and a far better end result in my book.
Clearance Hole Technology :P
Post Posted: Wed Dec 14, 2011 4:45 am
Told ya :P
Post Posted: Wed Dec 14, 2011 4:47 am
Littlejeep has a LJ ute cab on a SJ ute chassis, some headaches involved for sure, and that's with traybacks. Sierra has a longer wheelbase so work involved to get wheels in wheelarches etc.
Post Posted: Wed Dec 14, 2011 10:25 pm
chassis are 10mm different. im getting it road werthy so i can class it as a body swap. but if i keep the lj's chassis i have to class it as an engine replacement tranfer replacement axle replacement brake replacement. so its a lot less hassel just doing a body swap don't ya think :?
Any 4wding
Post Posted: Wed Dec 14, 2011 10:27 pm
ow and the diesel has craped its self
Any 4wding
Vehicle: LJ50 , LJ80Q-II
Post Posted: Wed Dec 14, 2011 10:32 pm
Putting a LJ Body on a SJ is sort of like putting a Ferrari Body on a VW Chassis
Id Put a Serria body on the the Serria chassis .... then its just a body swap.
Save the LJ . Don't Butcher it.
Post Posted: Wed Dec 14, 2011 10:40 pm
im not going to butcher the body im not changing any of the body
Any 4wding
Post Posted: Wed Dec 14, 2011 10:44 pm
you wont fit the wheels on an SJ chassis in the wheel holes on an LJ, they are alot difference in wheel base
Post Posted: Wed Dec 14, 2011 11:05 pm
ya 10mm thats a lot
Any 4wding
Post Posted: Wed Dec 14, 2011 11:14 pm
unless the SJ has been shortened its more than 10mm,
I own both cars and i can tell you the wheel base difference is atleast 3-4 inches
Post Posted: Wed Dec 14, 2011 11:20 pm
the sj's a 1984 high top mate would u b able to check the cars for me please
Any 4wding
Post Posted: Wed Dec 14, 2011 11:21 pm
your car i ment and told me what it is
Any 4wding
Post Posted: Wed Dec 14, 2011 11:31 pm
Chassis dimensions
LJ -this site is cool http://www.offroadrunner.nl/home.html
Sj70 swb WT www.suzukiinfo.com
So with basic maths..
The SJ swb wheelbase is 2030mmlg
The LJ swb wheelbase is Around 1941mm(no definate measurements on that diagram)
itsabitmorethan10mmbrowhenisschoolholidays?
http://www.4x4.in.th/specification.html
LJ is 76 inches
SJ is 80 inches
so about 100 mm difference
Post Posted: Wed Dec 14, 2011 11:59 pm
Thank bud il see if I can make in work
Any 4wding
Post Posted: Thu Dec 15, 2011 4:45 am
Nope, and nope. Just more mod codes, not more hassle.
Post Posted: Thu Dec 15, 2011 4:51 am
I will have a go at most things and have just been out and had a look at both the Zooks you are talking about (in my car lot) and while I think it could be done it would be far more trouble than it's worth I feel.
Post Posted: Thu Dec 15, 2011 5:44 am
It is il load some pics saturday
Any 4wding
Post Posted: Fri Dec 21, 2012 10:00 pm
Got those pics yet?
Post Posted: Tue Jul 08, 2014 5:39 pm
Because? :?
Post Posted: Tue Jul 08, 2014 6:44 pm
Sierra is 2030
LJ is 1930
Post Posted: Tue Jul 08, 2014 6:49 pm
sorry?
Post Posted: Tue Jul 08, 2014 7:48 pm
Kas is talking wheelbase. :wink:
The chassis is the big let down on a Sierra over an LJ.
A Sierra (any generation, eg an SJ40 chassis has different crossmembers to a 1.3l) has all sorts of things welded to the underside of the chassis as well as that giant rock anchor/transfer case. LJs have a flat bottom with nothing to get hung up on and no venerable mechanicals. Sierra chassis are wider and use larger tube, potentially resulting in less chassis flex(this is one highway-star goes on about a bit). The spring hangers are more intrusive in a Sierra, thus easier to get hung up on. LJ ones flow fairly neatly with the chassis. Sierra chassis has some rear over hang, which the LJ doesn't, giving a worse departure angle.
There's a whole bunch of other things like LJs run narrower bumpstop spacing in the front (for more flex), have slightly longer front springs, much greater difference in roll centres (higher rear, lower front) ect.
On the plus side, a Sierra mounts the engine/gearbox lower and further back, the body mounting outriggers are better placed (not to mention the body its self is mounted 9001x better) and the chassis aren't massively rust prone like LJ ones.
Another thing that isn't the fault of the designers but certainly is a little bit of a pain, 100x50x2.5 (sierra chassis) is super easy to find, unlike 7somethingx45x2.5 (LJ) which is handy if you want to do chassis extensions and so on.
Post Posted: Wed Jul 09, 2014 8:32 am
Thanks Sidways
Users browsing this forum: Google [Bot] and 384 guests
