It is currently Mon Oct 26, 2026 5:38 pm
Post Posted: Wed Jul 02, 2014 12:40 pm
Hi All!
Long since gotten rid of my Sierra but still rooting around with Suzuki stuff. Currently putting together a frankenstien 5K for a KE70 corolla and was wondering if anyone has the M16A standard compression/piston height? Just need to know before I splash out on some new slugs.
TIA
Post Posted: Wed Jul 02, 2014 7:58 pm
Standard compression ratio is 11 to 1. Do you need gudgeon to crown height?
Post Posted: Thu Jul 03, 2014 10:13 am
Yes please Losfer! If you know the CC volume of the dish that'd be appreciated too but it's not vital.
Post Posted: Thu Jul 03, 2014 7:54 pm
Unfortunately ive never had the opportunity to cc the dish and combustion chambers of m series engines . Cc'd heaps of g series engines. No matter what the end result you are trying to achieve theres 1/2 a dozen ways to increase or decrease compression ratio. In the real world you build your engine with the best available components then change the compression ratio to suit your needs afterwards.
Post Posted: Thu Jul 03, 2014 10:21 pm
Not wrong - decking both the block and maybe the head will be required. Thats why I'm not too fussed on CC volume, I'll just measure it when the rotating assembly is together.
Just trying to get the right piston/rod geometry, K series motors have a high compression height making them a slut to match anything up with.
Post Posted: Sat Jul 05, 2014 1:19 pm
Bump, still looking!
Post Posted: Fri Jul 11, 2014 6:51 pm
Bump!
Post Posted: Fri Jul 11, 2014 6:54 pm
i'm guessing losfer would be the only one on here with that sort of knowledge & i believe he's posted what he knows...
Post Posted: Fri Jul 11, 2014 7:47 pm
You may be right but he hasn't actually said no yet - guess it's a no by default.
Vehicle: 2012 Jimny
Post Posted: Fri Jul 11, 2014 8:20 pm
try redlinegti some useful info on that forum
Post Posted: Sun Jul 13, 2014 10:25 am
Cheers Paul. Already had a look, most of the RS416 owners seem to be more interested in wheel offsets and bolt on body kits, but I'll start a thread.
Users browsing this forum: No registered users and 258 guests
