It is currently Wed Oct 28, 2026 9:12 am
Vehicle: SJ50 hardtop!
Post Posted: Thu Jul 10, 2014 8:35 pm
Hey guys,
Finally got a bit of motivation to pull the dodgy ass RHS "body lift blocks" out of my sierra ute. I thought that would be the end of the bad fabrications but it turns out the body studs themselves have been SIGNIFICANTLY shortened.
Without a tape I'd be guessing to about 15/20mm long.
I'm wondering what my options are as their is no chance of the Just_cruizin female bolts grabbing or even of going back to no body lift as the studs just aren't long enough.
Cheers,
Alex
NT SJ50
Post Posted: Thu Jul 10, 2014 8:46 pm
Cut the floor, fit regular bolts. It's all you can do.
I've seen this too many times.
Post Posted: Thu Jul 10, 2014 8:49 pm
Urghhh, I think the hardest part of doing that is finding someone who knows what they're doing. I just don't think I can trust any shops who don't have a general idea about cars.
I thought about shortening the female bolts and body blocks but too risky if it's ever rolled or in an accident.
Might have to get everything else done for a roadworthy and then take it to Melbourne to get fixed. Just a tonne of $$$ for a few studs dammit
Cheers Steve
NT SJ50
Vehicle: Drover pickup turk
Post Posted: Thu Jul 10, 2014 8:57 pm
http://www.auszookers.com/forum/viewtop ... 84#p524084
.....maybe?
I like the tuna here
Post Posted: Thu Jul 10, 2014 10:06 pm
Hmmm, might work but still seems a bit on the dodgy side of things. It's a question of will that still retain a good amount of strength in the case of an accident more then will it make my cab mountable.
NT SJ50
Post Posted: Thu Jul 10, 2014 10:13 pm
Yea fair enough, I'd do what Gwagen suggested if possible.
Post Posted: Fri Jul 11, 2014 9:48 am
Going to ponder on it a bit more as I'd really be left with no choice other then to tow it 5hrs to Melbourne to get it done and that'll start to rack up the cost...but I still want it to be safe.
Will the way superduki be ok with I dropped it back down to standard? That way the "dowels" as such won't have to be nearly as long or added to with the female bolts.
NT SJ50
Post Posted: Fri Jul 11, 2014 4:15 pm
How much body lift are you after?
If it wasnt really important, could you use the female bolts etc for a 2" kit, and only do a 1" body lift?
Post Posted: Fri Jul 11, 2014 5:22 pm
That would work but there isn't thread the whole way up the inside of the female bolt. I suppose I could cut both the block and the female bolt down to match....but even then there won't be a whole lot of "grab".
NT SJ50
Post Posted: Fri Jul 11, 2014 6:22 pm
Pm want33's he had the same problem with his white lwb not sure what he done to fix it though
Post Posted: Sun Jul 13, 2014 6:41 pm
Have you tried the body lift bolts as yet? How much bolt is left
Post Posted: Sun Jul 13, 2014 8:40 pm
The female bolts supplied in your kit are not even close to grabbing. I can take a photo tomorrow but I'll upload one I have at the moment of the old blocks and amount of stud left
NT SJ50
Post Posted: Sun Jul 13, 2014 8:41 pm
NT SJ50
Post Posted: Sun Jul 13, 2014 8:45 pm
:( thats gay
Post Posted: Sun Jul 13, 2014 8:54 pm
Mhmm. Because other then these 4 outside studs being chopped down, it's really quite tidy.
NT SJ50
Vehicle: sj51
Post Posted: Mon Jul 14, 2014 5:11 am
Strip the cab down, bung it in the back of your ute, bring it to mine and ill weld in some new studs :D
we can 45 your sills whilst we are at it
Post Posted: Mon Jul 14, 2014 10:15 am
Might aswell trailer the whole damn thing and spend a weekend on ya bender aswell lol. I can supply all the beers haha
NT SJ50
Vehicle: sj51
Post Posted: Mon Jul 14, 2014 7:25 pm
That will work, but I dont have a bender :(
Post Posted: Mon Jul 14, 2014 7:30 pm
That is a 1.0lt body on a 1.3 chassis hence the issue. I have done bolts for these in the past, I get some done and swap them over. I'm out with work for a couple of weeks but if you can wait ill sort it.
Post Posted: Mon Jul 14, 2014 7:32 pm
Really?? I thought it was all standard. All the plates and numbers match and the tunnel hasn't been changed.
The bolts look chopped.
I can wait!
NT SJ50
Post Posted: Mon Jul 14, 2014 7:53 pm
Could be but whoever did it went to a lot of effort to thread the studs all the way
Post Posted: Mon Jul 14, 2014 9:19 pm
I've seen a body lift done exactly that way before in Vic. I took some photos of the car I saw it on. What a hideous mess. The car I looked at also had shock mounts, exhaust, and a traction bar all fitted above the body lift, so that would have all cut out to take the horrid BL out. Waste of a clean WT.
Post Posted: Mon Jul 14, 2014 9:20 pm
When I did the BL on my old sierra I used solir steel stock cut to length and had a hole drilled and tapped in the middle for this exact reason.
screw the tapped BL block on and then a bolt up into the bottom of it. Use lots of Locktite
Never came loose with all the flogging I gave it.
Post Posted: Tue Jul 15, 2014 6:12 am
That method still requires you to cut the studs to allow room for the bolts up through the chassis
Post Posted: Tue Jul 15, 2014 7:05 pm
but in Bucket's case the studs are already cut and if he wants to install body lift blocks then its one solution
Post Posted: Tue Jul 15, 2014 7:51 pm
But he already has a kit and I am giving him a $15 solution
Users browsing this forum: Google [Bot] and 264 guests
