It is currently Fri Oct 23, 2026 6:48 am
Post Posted: Tue Sep 01, 2009 1:02 pm
Hi all, Hopefully will get my new/2nd hand diff centre today or tomorrow. Am wondering about sealant between the diff carrier and the axle housing. Is there a specific product I should use or do you guys have any preferences for other products.
No "backyard patch ups" using liquid nails please. LOL :wink:
Post Posted: Tue Sep 01, 2009 1:22 pm
I use ThreeBond
Post Posted: Tue Sep 01, 2009 1:28 pm
ScrawnC wrote:
I use ThreeBond
Is that vehicle specific? Repco, SuperCheap?
Post Posted: Tue Sep 01, 2009 1:32 pm
I use permatex/Loctite Ultra Grey.
The owners manual lists Suzuki Bond No 1215 9900-31110
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Tue Sep 01, 2009 1:37 pm
My Jimny Manual states; Sealant 99000-31110 (same, same, but different??)
Post Posted: Tue Sep 01, 2009 1:57 pm
any RTV silicon stuff will do the trick.
Post Posted: Tue Sep 01, 2009 2:07 pm
Sorry my bad! 1215 99000-31110, its the same
Zuki
Now just drive i
Post Posted: Tue Sep 01, 2009 2:48 pm
ultra anything
three bond forma gasket stuff
dont use stuff designed for bike cases like loctite 515 it might be a bit thing for teh surfaces
Post Posted: Tue Sep 01, 2009 3:16 pm
X 2... Grey silicone sealant made for aluminium.. Works great and is easy to clean off if need be.
Post Posted: Tue Sep 01, 2009 4:04 pm
I use the grey stuff on everything that doesnt get hot. Engine stuff i have been using the red one, seems to work well... no leaks :wink:
Vehicle: 1999 Jimny
Post Posted: Tue Sep 01, 2009 8:33 pm
ScrawnC wrote:
I use ThreeBond
Gotta agree scrawn, one of the the best I have used as well.
Post Posted: Tue Sep 01, 2009 9:58 pm
3m make a gasket does the trick for me :)
85 NT, SPOA, 2" BL, sliders, f&r lockers, bull bar
Post Posted: Tue Sep 01, 2009 11:23 pm
ScrawnC wrote:
I use ThreeBond
X3 best stuff. :wink:
Post Posted: Wed Sep 02, 2009 12:55 am
ScrawnC wrote:
I use ThreeBond
X4 love it
Post Posted: Wed Sep 02, 2009 12:57 am
ThreeBond sounds like it may get the nod. Thanks for all the suggestions.
Will I find ThreeBond at auto parts shops?
Post Posted: Wed Sep 02, 2009 1:03 am
U should. If not the Ultra rang is very good for the $$`s, blue is sensor safe to.
Vehicle: 105 landcruiser
Post Posted: Thu Sep 03, 2009 4:41 pm
whist on the subject anyone have any good tips of getting the carrier out when caked in sealant?
Post Posted: Thu Sep 03, 2009 4:56 pm
Encouragement with a soft hammer. Otherwise try a flat blade screwdriver and hammer between housing and carrier.
Post Posted: Thu Sep 03, 2009 5:07 pm
hmm tried both. it's stuck pretty fast
Post Posted: Thu Sep 03, 2009 5:52 pm
Put a jack under the flange and jack it up slightly. It will crack the seal, just be careful it doesn't come out at the same time.
Post Posted: Thu Sep 03, 2009 6:21 pm
Just in case, have you pulled the axles?
Post Posted: Thu Sep 03, 2009 10:39 pm
tried that Damo. the whole kaboodle twists without the "A" arm attached.
next step is to get someone to hold a block of 4x2 against it while I give it a good belt.
if that fails ,remove the entire diff assembly and then I can persuade it more forcefully.
yeah man axles are pulled 8)
Post Posted: Thu Sep 03, 2009 10:43 pm
Cool, you never know.
Post Posted: Thu Sep 03, 2009 10:55 pm
Step 1 If at first you don`t succeed, get a bigger hammer.
Step 2 See step 1
Step 3 See step 2
Users browsing this forum: Google [Bot] and 143 guests
