It is currently Sat Oct 24, 2026 10:38 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Vehicle: Suzuki Jimny JLX manual 07/13
Post Posted: Thu Jul 03, 2014 2:03 pm
Not any real difference. The only thing I have found is i will have to put four bolts instead of two and a bit of 2mm sheet to stop eliminate the small amount of bounce in the bracket. Might even just put a small strut of 3/8 rod down a bolt head.
Vehicle: 2012 jimny
Post Posted: Thu Jul 03, 2014 8:12 pm
Jezza86 wrote:
how warms the water get in the windscreen washer bottle there?
Be good for frosted up windows in winter i reckon lol.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jul 03, 2014 8:23 pm
In the NT i could steam clean my windscreen i reckon. mine allready gets hot (50-60C) and its nowhere near that close to the headders thats all.
Vehicle: 2013 jimny
Post Posted: Fri Jul 18, 2014 12:19 pm
I ended up getting the 55AH slimline batter, wired up a socket box and stuck it to the top with vhb tape.
Charges from a waeco RAPS socket that is fixed to the back of my handbrake shroud, where the cup holder is.
Strapped it to the side of the fridge to secure it. Seems pretty good so far, but havent run it on a camping trip yet.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jul 18, 2014 12:49 pm
nice small and tidy setup. how will you strap it down?
Vehicle: 2013 jimny
Post Posted: Fri Jul 18, 2014 1:19 pm
I've got my fridge strapped down both ends by the handles. The battery has another strap wrapped around it, strapping it to the side of the fridge (you can barely see the strap in the pic), The battery strap goes through the battery handles and the fridge handles to try and stop it slipping out. I'm thinkng about swapping the rope handles on the battery to something stronger like cables, for a bit more strength.
As far as cost goes, I think it was a touch over $350 all up.
RAPS RU2-12R - $99
55AH Slim Battery - $195
Connector box with volt meter - $60
Vehicle: Suzuki Jimny 2013
Post Posted: Thu Aug 14, 2014 7:53 am
Hi guys, I have a bit of an update in regards to this thread, I was recently referred to a custom fabrication shop in Brisbane known as Buds customs, they were able to construct me a dual battery tray for a 2013 Jimny (with aircon), I don't have the battery yet but the tray is installed!! It has been designed to fit an Optima D34, but i have been looking around to see if i could find a higher capacity dedicated deep cycle battery... most that would fit this tray are about 70 Ah but I think they will be too tall ~215-225mm where as the Optima D34 was only 199mm to top of terminals...
The moved the washer bottle a bit closer to the exhaust manifold so hopefully this will be okay... I know someone who had that mod done and they were saying their engine overheated long before that got too hot...
Photos!
Post Posted: Thu Aug 14, 2014 9:30 am
looks good...
Vehicle: 91 Tin Top
Post Posted: Thu Aug 14, 2014 9:54 am
Thanks for the pics mate, I always thought it could be done.
My thoughts where to used the washer bottle mounts as you have done. But to off set the brackets towards the headlights to try and squeeze the washer bottle between the battery and the ABS, with the bottle facing the same way as you have it on the firewall.
Also;
It would be worth popping the hood after a decent drive one day and feel how hot the pumps and hoses are above the exhaust. If you're worried about it, a small piece of sheet metal between the manifold and the bottle will make a big difference.
*Edit*
Just saw the pics on the first page. Thanks ALBYALBATROSS1 too.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Aug 14, 2014 9:57 am
very tidy! you an also get batteries with side mounted terminals which may give you an extra 40mm
Post Posted: Thu Aug 14, 2014 12:47 pm
Nice piece of fab work they did for you. The temp is not extreme as most seem to think. As long as no hoses or the resivoir itself do not touch the mainifold ect.. it will be fine. just be aware of if thereis any movement as in shake up and down of your bottle.
Post Posted: Tue Sep 02, 2014 6:45 pm
Just a bit of a thread update here... I ended up going with a cheaper option than the Optima D34...
I bought an Exide LM50D it was far cheaper, though a smaller battery and not really a deep cycle per say... specs are 350CCA, 40 AH... was about 188cm tall so slightly less than a D34... biggest plus was it cost $80! Just waiting on the wiring/fuse block to arrive so I can install it with an isolator I already have :)
Post Posted: Sat Mar 28, 2015 2:40 pm
I would not recommend Buds Customs!
I payed Buds Customs on 8 January 2015 for this tray when told it would be 3- 4 weeks.
After many excuses and poor email responses I got a PayPal refund on 26 March 2015 after logging a PayPal dispute.
Just another take you money and have a interest free loan type of company was the impression I got with my dealings.
Users browsing this forum: No registered users and 139 guests
