It is currently Wed Oct 21, 2026 7:16 pm
Post Posted: Thu Sep 03, 2009 10:56 pm
It would seem that the outer housing for Jimny Diff centres has had at least 4 variations in the last 11 years. I'm interested to know what other ratios are available and which centres from other Suzukis are interchangeable.
The ratio that I have in my early Mark II Jimny with manual tranny is 4.09:1 (Crown = 45 teeth / Pinion = 11). When I received delivery of my replacement diff centre today it had a different shape carrier housing. I went down to the local car park and checked 3 others out. I worked out there are at least 4 variations. I also wonder how many ratio variations there are.
I'm new to the world of the inner workings of an axle and am interested to see what is interchangeable.
I also still have my old diff centre and would be interested to see if it mates with sierra axle housings etc...
Post Posted: Fri Sep 04, 2009 12:23 am
3.7.....3.9.....4.09......4.10.....4.3.....4.6.....4.8......5.1.
all rears 26 spline. sierra fronts 22 spline, most vit fronts 22 spline late vits and grands 26 spline fronts. vit and grand front diffs same as sierra except xl7 (salisbury type).
coily front diff reverse cut sierra 1.3 size centre. jimny front diff reverse cut sierra 1 litre size centre.
Post Posted: Fri Sep 04, 2009 12:24 am
off the top of ya head.
Post Posted: Fri Sep 04, 2009 12:31 am
I'm impressed 8O
Post Posted: Fri Sep 04, 2009 12:37 am
Does this mean the Jimny front diff is a bit weak "1 litre size centre"
Post Posted: Fri Sep 04, 2009 12:40 am
I'm impressed 8O
thats what all the girlies say :wink:
you're front is reverse cut so is stronger than normal 1 litre, you're axles are about the same though. and jimny's have too much front diff tube flex, hence their king pin inclination machining is different to all other solid axle zooks.
and don't get me started on all the axle, offsets and width combos you could build from zook parts............
Users browsing this forum: No registered users and 112 guests
