It is currently Mon Jun 08, 2026 2:35 am
Vehicle: 1998 Vitara SV420 2.0ltr 2dr
Post Posted: Wed Oct 01, 2014 7:37 pm
Hey guys,
I got some suspension, just wondering because i got 2 shocks that i assume are going installed in the rear, wouldnt the rear of the vehicle be alot higher than the front?
Post Posted: Wed Oct 01, 2014 7:41 pm
Shocks don't have any effect on vehicle height.
Post Posted: Wed Oct 01, 2014 8:57 pm
I was told they were a 2inch suspension lift kit?
They look alot taller than normal standard shocks
Vehicle: 2002 Suzuki XL7
Post Posted: Wed Oct 01, 2014 9:07 pm
They will probably allow up to 2" lift by way of fitting heavy duty (Raised springs) which either are taller or more heavy duty (don't Compress as much) Or alternatively spring spacers.
You could install them with the standard springs (If not to long) but will make no difference in height (you will need spacers to raise the vehicle). if no spacers are fitted with standard springs and the shocks are too long you are at risk of dislodging a spring when a wheel gets off the ground. Hope this makes sense?
What shocks did you get?
Post Posted: Wed Oct 01, 2014 9:47 pm
They will extend further than stock shocks, and probably bottom out sooner than stock shocks. Unless they bottom out before your springs are taking the weight of the car they won't change the ride height. Springs do that.
You need longer springs to match the shocks, and then yes, the rear will sit higher than the front, so you'll need longer struts and taller front springs to suit.
Vehicle: Which one?
Post Posted: Wed Oct 01, 2014 9:59 pm
Much in the same way that a bigger pillow case doesn't lift your head further off the bed, a bigger/longer shock absorber won't lift your car. Sure, it might "suit" a suspension lift in the same way a bigger pillow case might "suit a bigger pillow" but it won't do a damn thing on its own.
Post Posted: Thu Oct 02, 2014 9:36 am
sorry they are 2 dobinson struts and was promised they would lift the vehicle 2 inches
Post Posted: Thu Oct 02, 2014 9:38 am
Nope. Only springs control ride height. Struts and shocks have no effect.
Vehicle: Suzuki grand vitara 2010 jt
Post Posted: Thu Oct 02, 2014 9:41 am
Looking at better suspension and lift on gt any idea's
Post Posted: Fri Oct 03, 2014 8:58 am
Dobinson struts?
Struts = front
Shocks = rear
I would just get some king springs around 330 for 4 and that will raise it just under 2 " i havent seen many aus manufactures actually make a true 2" setup. its usually around 35 to 40mm, but 2 inch seems to be the golden sales number.
Post Posted: Fri Oct 03, 2014 9:33 am
Yeah that seems to be it thanks
Post Posted: Fri Oct 03, 2014 9:59 am
Sorry guys, just got a phone call and a box was lost in transit with all the other goodies!
Which means shitloads of freebies delivered to my door!
Thanks for your help anyway
Post Posted: Fri Oct 03, 2014 4:17 pm
That makes nearly as much sense as your first post...
Post Posted: Fri Oct 03, 2014 6:17 pm
Off-Chops post up a pic of what you currently have.
Post Posted: Thu Oct 09, 2014 12:29 am
my shoes have shoe laces
Users browsing this forum: No registered users and 6 guests
