| Author |
Message |
Ausx90
Vehicle: Suzuki x90
 Posted: Sun Nov 09, 2014 5:36 pm |
I'm after any info, prices, and any knob problems with turboing a g16b I'm not after big power just more torque
Thanks
neofitou
Joined: Wed Mar 24, 2010 10:30 pm Posts: 1088 Location: Melbourne
Vehicle: 00 Jimny, 63 Haffy
 Posted: Sun Nov 09, 2014 8:01 pm |
Basically if you need to ask the questions, you shouldn't be doing it. G16Bs are old and crack. First of all you will need a newer one from a Baleno, then make sure you have several thousand dollars handy to do it properly to strengthen the motor lower the compression a computer and dyno time. Turboing is generally not cost effective, if you don't need more power but need more torque, you probably just need some gear reduction. Gears: http://www.lowrangeoffroad.com/sidekick ... gears.htmlChris's write up: viewtopic.php?f=5&t=30281
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Sun Nov 09, 2014 9:29 pm |
Yes it can be done, but bang for buck, its not really worth it.
By that i mean youd get just as much or more power by doing an engine conversion to lets say a suzuki j20.
zook_ute
Joined: Sat Nov 14, 2009 10:30 pm Posts: 246 Location: glasshouse mtns
Vehicle: 1995 soft top vitara
 Posted: Mon Nov 10, 2014 6:11 pm |
Definitely worth it, could be done on a budget if your sourced the parts in good used condition. I always thought that they were weak, i have since found out they are pretty strong lol I think if you were to do it a head stud kit and a descent head gasket would be the go. hold 7-9 psi with a good computer and tune lol
buzbox
 Posted: Mon Nov 10, 2014 7:31 pm |
How much did it end up costing you?
zook_ute
 Posted: Mon Nov 10, 2014 7:43 pm |
Well i went arse about face way of doing it, i never had a problem with mine though. I bought my motor as a built motor with 10000ks on it with like 12k of receipts. turned out that I basically got ripped off and it was just a standard bottom. Unfortunately I didn't find that out until I sold the engine to a another bloke. it was a nothing short of a nightmare really :/
I ran 12 psi, Chapmans tuned it. standard bottom end.
I think you could do it for around 6k if you can do some of the work your self
Ausx90
Vehicle: Suzuki x90
 Posted: Mon Nov 10, 2014 8:53 pm |
Thanks for the replies for 6k it's not worth it to me, thanks any way
droverdave
Vehicle: 85 ' Drover
 Posted: Tue Nov 11, 2014 6:31 am |
How do you come up with 6k for mostly diy?
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Tue Nov 11, 2014 6:39 am |
droverdave wrote: How do you come up with 6k for mostly diy? A decent computer and tune is going to be around a third of that already?
Joshyboy26
Joined: Thu Sep 01, 2011 11:48 pm Posts: 814 Location: kinglake, VIC
 Posted: Tue Nov 11, 2014 6:51 am |
Assuming junkyard parts.
Turbo $500 manifolds exhaust etc $5-1000 depending on where from custom etc. sensors computer wiring. About $2500 Engine rebuilt not including any comp changes with pistons or rods etc. $1000 diy various hoses fuel lines injectors $800 Oils filters coolants. $200 And that's before a tune, all the little bits you forget and all the bits you fuck up and have to replace
droverdave
 Posted: Tue Nov 11, 2014 7:44 am |
I bought a Haltech E8 for $200, even came with a 3 bar map sensor and an air temp sensor. Still an excellent computer. No need to buy a brand new one. Look for bargains and the price will come down.
zook_ute
 Posted: Tue Nov 11, 2014 12:51 pm |
600-800 ball bearing t28 garret turbo from s15 300-bov and boost controller 300-intercooler 300-intercooler piping 300-braided water and oil lines for turbo 400-2jz injectors modify rail to fit 500-750 turbo manifold and dump pipe 600-2.5 inch zest with a descent muffler 500-700 second hand ems stinger 1000-wire competer, tune descent ignition setup 150 good head gasket 150 head stud kit 400- vl turbo external fuel pump and reg few hose fittings
it all adds up pretty quick, there would definitely be a few things I have missed. The big problem is that nothing is off the shelf really, everything needs to be made to suit. seems to be a few people out there that have gone threw with the conversion.
suzuki engines free rev, i loved the power delivery my last one had. surprised a fair few people, blew off my fair share of ss commodore, even give the fg turbos a good run hahaha
buzbox
 Posted: Tue Nov 11, 2014 1:52 pm |
Have a look on other forums like boostcruising, or redlinegti. They may be able to shed a bit more light on the process etc. A few of the Gti guys use the g16b block with twin cam head and other crap which may give you a few more ideas. A few years back I do remember a GTi being about 8th on the FWD 1/4mile top 10. But again, better off doing a proven engine conversion.
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Tue Nov 11, 2014 5:57 pm |
Check u have 5.12 diffs not 4.8 and get tc gears
vet 180
Vehicle: Vitara 1994
 Posted: Thu Nov 13, 2014 5:22 pm |
zook_ute wrote: 600-800 ball bearing t28 garret turbo from s15 300-bov and boost controller 300-intercooler 300-intercooler piping 300-braided water and oil lines for turbo 400-2jz injectors modify rail to fit 500-750 turbo manifold and dump pipe 600-2.5 inch zest with a descent muffler 500-700 second hand ems stinger 1000-wire competer, tune descent ignition setup 150 good head gasket 150 head stud kit 400- vl turbo external fuel pump and reg few hose fittings
suzuki engines free rev, i loved the power delivery my last one had. surprised a fair few people, blew off my fair share of ss commodore, even give the fg turbos a good run hahaha I am going to play devils advocate on this post, although I agree with the general msg as things do add up fast. No need for t28. A ca18 t25 with the .48 ex housing will be more suited, make boost earlier and still be capable to pump out 150rwkws. Can be had for $200-$300 Forget bov and boost controller. No need. Maybe budget $30 for a turbo tech $500-600 for cooler and piping seems fair using new parts. Can be done much cheaper if your scrounge and use steel piping. $200 for braided lined will be enough $400 is way too steep for 4 2jz injectors. There are other cheaper options. $1000 will be needed for basic log manifold, dump and exhaust with decent muffler $150 head gasket $150 studs $1000-1500 for decent ecu and wiring and basic tune seems fair $100 for the fuel pump, reg and fittings. $30 at u pull it will get you a camera pump which is the same as the vl turbo. Any Nissan rising rate reg will be fine. I think $3500-$4000 is defiantly possible with some shopping around and a little diy. Could be done much cheaper if you skimp on everything, but I think it's a fair budget for a good result.
