It is currently Sun Oct 18, 2026 10:30 pm
Post Posted: Sat Nov 15, 2014 8:24 pm
So, broke the top of my dipstick, anyone got one floating around after a Conversion?
Liana so might be the same.
May as well see if somebody has a fuel rail with a return while I am here
Vehicle: 09 Jimny JX
Post Posted: Sun Nov 16, 2014 6:50 am
i did the same. now need a pair of pliers to grasp the bottom bit :-(
Vehicle: Suzuki Jimny
Post Posted: Sun Nov 16, 2014 6:59 am
i did this whiping it down... might help to say what cc the engine you have is as that will be the dipstick you need.
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Nov 23, 2014 8:15 pm
I'll check out the dipstick tomorrow off my m18 and see if it's the same as the jimny. You're welcome to it if it is. Is it out of your swift?
Post Posted: Sun Nov 23, 2014 8:55 pm
Yeah for the swift, just measure from the stopper to the fill mark to see if they are the same.
Too easy :)
Vehicle: 2012 Jimny
Post Posted: Mon Nov 24, 2014 5:02 pm
Might be easier to just get a brand new one as Suzuki charged me only $18 (I snapped mine doing the swap to a M15a)
Post Posted: Mon Nov 24, 2014 5:58 pm
Yeh, My M15a one was like 1cm longer then the old M13a.
Post Posted: Mon Nov 24, 2014 8:54 pm
Liana dipstick left, Jimny on the right
Post Posted: Mon Nov 24, 2014 8:56 pm
yeh so obviously if you put the Liana engine in. use the Liana dipstick...
Post Posted: Mon Nov 24, 2014 9:02 pm
Actually no. The Liana stick is matched to the sump, different location on the rocker cover too.
Post Posted: Mon Nov 24, 2014 9:04 pm
ohk, because I measured the length of the block to get know which dip stick to use lol. liana block is longer... Pickups where the same depth...
Post Posted: Mon Nov 24, 2014 9:10 pm
I'll have to check, just assumed the block was the same. Hmm
Post Posted: Mon Nov 24, 2014 9:18 pm
nah... I got worried when my mate went to stick the Jimny dipstick in because the 1.5 one was hitting the bottom of my sump. so i but the Jimny tappet cover on and measured from the sump gasket to the dipstick hole... but the extra 500ml you would get from the Jimny dipstick wouldn't hurt it I dont think.
Post Posted: Tue Feb 09, 2021 2:50 pm
These crappy dipsticks appear to have a code stamped in the metal just below the plastic bit. My Jimny has 80A (bought as a replacement for M13 Jimny from Mr Suzuki). The conversion to M15 was done b4 my ownership so confirmation from someone with original M13 Jimny would be good. The Swifts etc may all be different as well.
M18 Liana has 69G and is a bit longer with full/low markings somewhat different as well.
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Post Posted: Tue Feb 09, 2021 3:09 pm
It turns out the stamped code is part of the genuine part number !!! So 80A is Jimny M13 and 69G is M18 Liana
Users browsing this forum: No registered users and 27 guests
