It is currently Sun Oct 25, 2026 1:49 pm
Vehicle: 93 LWB Vitara
Post Posted: Sun Dec 21, 2014 1:10 pm
It would appear I do not have the key for this spare wheel lock. I have no idea how these work or what they look like underneath, what's they best way to butcher it off? Cut along the length or can you bust the lock out with a screwdriver and a hammer?
Vehicle: LWB Sierra & XL7
Post Posted: Sun Dec 21, 2014 3:58 pm
I'd bust the lock and go from there but maybe try some vice grips or one of those chain clamping tools to remove it.
'92 Vitara & Camper trailer
Post Posted: Sun Dec 21, 2014 5:36 pm
A locksmith could get it off or even make a key for it. Depending on what you want to spend.
Post Posted: Sun Dec 21, 2014 7:51 pm
Could try a screwdriver or small cold chisel to hammer it in and twist with a small spanner or vice grips
Could try using a cold chisel on an other edge.
Can you hammer a socket onto it?
Post Posted: Sun Dec 21, 2014 8:27 pm
Smack it with a hammer until the outer case comes off then force a socket over the bit left and undo it with a ratchet.
Should take about 20 seconds.
Post Posted: Sun Dec 21, 2014 8:47 pm
They are a pretty simple design if its the same as the one as on the GVs. You don't need to turn the key or anything, just simply insert it and then pull it straight off. I thought I had the wrong key on mine at first as I kept trying to turn it.
Try a few different keys and if you still have no luck blade screwdriver & hammer.
Post Posted: Mon Dec 22, 2014 3:21 pm
As an update turns out it was the car key haha and just a sticky lock. Thanks guys!
Post Posted: Mon Dec 22, 2014 10:50 pm
i watched a tyre fitter put a snap-on socket over a lock nut once and go to town on it with a hammer until it formed its own hex head onto the nut... he then used a rattle gun and took it off... when he looked at the expression on my face he said "well, if i break it they'll replace it so why not" LOL
Took all of about 30seconds too...
Vehicle: 1997 Sierra SJ80
Post Posted: Thu Jan 01, 2015 11:02 am
There are some peeps with locking wheelnuts who think tyre shops have a "master key" so they leave their lock key at home so they dont lose it.
I've bashed an impact socket on many times to get the lockies off.
The ones picced above, I always try a cable tie first (after I try the Key!) Works on about 1/2 of them.
Post Posted: Tue Jan 06, 2015 4:29 pm
Thats how we got the ones off my new gv the other day
Users browsing this forum: Google [Bot] and 194 guests
