It is currently Sun Oct 25, 2026 1:37 am
Post Posted: Tue Dec 23, 2014 4:27 pm
As most of you know im looking at a h27 for my buggy.
to broaden my search a bit I'm trying to figure out what's the same and what's different when it comes to H J and G series motors.
What I know already.
* G16 and J18 and J20 bell housings are the same pattern and bolt up
* G16, J18 and J20 are different to H20
* J series motors have an 8 bolt pattern on the crank where the fly wheel/ flex plate goes.
* G series all have a 6 bolt pattern on the crank
* J18 fly wheel is the same thickness and diameter as the G16 flywheel. (bigger than a G13 flywheel)
* J20 is bigger than the J18 fly wheel.
Some points i'd like to find out if I can
1. are the H series cranks the same 8 bolt pattern as the J series
2. do the H series autos use a combined ecu/tcm or are they separate the same as g16 auto tcms.
Vehicle: Which one?
Post Posted: Tue Dec 23, 2014 6:56 pm
1. There are 8 bolts on an H25a/H27a flex plate
Post Posted: Tue Dec 23, 2014 7:55 pm
Hmm wonder if its the same spacing
Post Posted: Tue Dec 23, 2014 8:03 pm
i can get a rough pcd off the h25/27 flywheel or off the crank.
will get those h27 int/exh port pics uploaded to. :oops:
Post Posted: Tue Dec 23, 2014 8:23 pm
Basically im hoping I can get a manual car or an auto. And just adapt the gearbox I already have
Post Posted: Wed Dec 24, 2014 12:11 am
It may depend on the market the car was built for, but as far as I know, it's a combined PCM (powertrain control module), but, the transmission is the same so you could use the G16 controller once you work out how the two communicate - if I recall correctly there was someone on here building a circuit to do just that..
Post Posted: Wed Dec 24, 2014 7:48 am
yeah Jrzook is a mate of mine.
He just needs to pull his finger out
Users browsing this forum: No registered users and 130 guests
