It is currently Fri Oct 23, 2026 11:37 pm
Vehicle: suzuki sierra sj80
Post Posted: Tue Apr 07, 2015 5:45 pm
Hey guys how hard is it to remove cv joint then split the cv to be able to remove and install new boot on a suzuki vitara
Post Posted: Tue Apr 07, 2015 6:26 pm
There are boots available to fit around without pulling them out, ask at auto shops.
But I have never tried them, so no idea how good they are.
Passenger side is easy to remove, but drivers can be a bitch, lots of disassembling to slide the inner cv out of diff.
Theres circlip on outer end of outer cv behind the free wheel hub.
And 3 bolts on inner for passenger side.
And drivers side slides into diff.
Post Posted: Tue Apr 07, 2015 7:33 pm
Ok buddie thank you thinking i might just replace it has alot of grit in the grease
Vehicle: '89 Suzuki Vitara
Post Posted: Thu Apr 09, 2015 12:16 pm
I had to do mine to get a RWC. Wasn't too difficult. I took the whole passenger side apart, but I also needed to do the A arm bushes, so if it was just the boot, just drop the shaft out, take it apart and change the boot.
I'd recommend doing both ends (inner and outer) while you have it apart, a boot is like $15, may as well change both while you're there.
Post Posted: Thu Apr 09, 2015 4:09 pm
The outter side how do u split the joint inner seams to pull apart the outter is fixed
Post Posted: Thu Apr 09, 2015 5:15 pm
Internal locking ring springycirclip thing hiding in the grease
Post Posted: Fri Apr 10, 2015 10:16 am
So u have too knock it off with a dolly ??
Post Posted: Fri Apr 10, 2015 12:27 pm
No, circlip pliers and/or 2 screw drivers to hook it out, on mine anyway, guess there could be different types.
Post Posted: Fri Apr 10, 2015 2:20 pm
Here is a document I put together after dealing with Boot damage on a SWB '96 Tracker (Vitara) I once owned:
http://acksfaq.com/cvhalfshaft.htm
The short side axle shaft is a pain to remove. I went ahead and removed both the strut bolts and the A-arm ball joint in order to remove the shaft for "re-booting". In retrospect, I could have done it with only the strut bolts removed. Since I had the unit apart, I completely cleaned out the old grease and then reapplied new grease to the joint before installing the new boot.
Split boots are, in my opinion, a waste of money.
Zip (sometimes called "baker") ties work only in an emergency as they degrade with exposure to the elements. Use the steel bands that come with the boots.
I hope that this helps!
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Fri Apr 10, 2015 6:28 pm
Cheers guys found a crack in my old cv so ordered a new one
Users browsing this forum: Google [Bot] and 121 guests
