It is currently Sat Oct 24, 2026 9:41 am
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Apr 10, 2015 4:40 pm
Hey Guys,
Long story short, I need to pull the woodruff key from my m13 to replace the m18 one. I can't seem to figure anyway of removing it, other than removing the crankshaft... Surely this can't be right can it?
No amount of searching helps. The g series motors are accessible once you take the timing gear off, but m series are chain driven and the only thing that covers the key is the crank pulley. I've tried grabbing it with pliers etc but no luck.
It's also only a $3 part, but I was hoping to use the 1.3 as a learning experience for when I get to the 1.8
Any help would be appreciated :)
Tim
Post Posted: Fri Apr 10, 2015 4:49 pm
It should just knock loose with a small hammer or something
Post Posted: Fri Apr 10, 2015 4:59 pm
There's no real space to get a hammer in there :(
Vehicle: Sierra
Post Posted: Fri Apr 10, 2015 5:20 pm
You should be able to tap it with a punch enough to have it lift out of its spot enough to pull it out, they generally aren't that tight
Post Posted: Fri Apr 10, 2015 6:04 pm
Screwdriver on the end of it and a light tap with a hammer. Try and lift the end. Could try some WD-40 or similar
Post Posted: Fri Apr 10, 2015 7:44 pm
Thats the bottom timing chain gear. you aren't getting the key out without pulling all the chain and that gear off first
Post Posted: Fri Apr 10, 2015 7:50 pm
Does that keyway go right through? Two pulleys on one?
Vehicle: Vitara 1994
Post Posted: Fri Apr 10, 2015 10:45 pm
Just buy a new key, will save the headache
Post Posted: Sat Apr 11, 2015 6:44 am
exploded views
Users browsing this forum: No registered users and 131 guests
