Have a look at Jimnybits.co.uk, they have good coils. I run their 3" coils and love em. I would probably recommend the same for your build instead of going body lift path. That will see you running up to 31s with a bit of bashing guards etc. Anything over that I'd go bodylift.
Holden Commodore or Camira rear shocks and swap out the bush or just the eye to suit. I just drilled mine out.
Few brand on the market to choose from, if I was to get another set I'd personally go OME.
Definitely get a set of Camber Bolts if you don't have some already, and also some diff drop brackets. Both can be bought from Jimnybits
Here's a few pics
Soup Kitchen - Dobs 35mm lift kit, 225/75R16 KL71s.
Build Thread -
viewtopic.php?f=4&t=44020
Brad's GV - XL7 40mm Lift (Lifted 90mm on GV) on 225/75R16 KM2s.
Build Thread -
viewtopic.php?f=4&t=46777
Ninjamoses XL7 - Calmini 2.5" front springs and custom rears to suit, Dick Cepek DC2 16x8 -12 wrapped in 245/75R16 Goodyear Duratracs
Build Thread -
viewtopic.php?f=4&t=27787
Ninjamoses's old GV - 2.5 Calmini Kit, 2" Body Lift, same wheels/tyres.
My GV - 3" Coils, 2" Body lift, 235/85R16 Mudhogs
Build Thread -
viewtopic.php?f=4&t=32683
The IFS Toy COMP TRUCK - 35x12.5 on 16x7 -12 Sunraysias, 2" lift with a lot of cutting guards.
Build Thread -
viewtopic.php?f=4&t=46549
That should give you a rough gauge of what your GV should look like with different size lifts etc.
