It is currently Sat Oct 24, 2026 6:40 am
Post Posted: Thu Aug 06, 2015 6:59 pm
This might seem a bit noobish but no amount of searching has revealed an answer.
Helping a mate with putting a g16b vitara engine into a sierra. What have people done to get bonnet clearance without running a bodylift?
Vehicle: '96 LWB trayback
Post Posted: Thu Aug 06, 2015 9:16 pm
It clears a standard Wt bonnet without issue.
Post Posted: Thu Aug 06, 2015 9:31 pm
Really? Mines dropped down and crossover intake pipe only just clears the bonnet. It might depend on which variant of g16b as to which manifold clears the bonnet. My engine is bolted in the the engine mounts that come in the low range offroad conversion kit. They were sold to me separately.
Post Posted: Thu Aug 06, 2015 10:11 pm
A Jimny or Baleno Inlet Mani had more clearance than a Vitara one.
Post Posted: Fri Aug 07, 2015 5:35 am
Nope. If it did I wouldn't be asking the question.
Jono how did you drop yours? Custom engine mounts or purchased from somewhere?
Post Posted: Fri Aug 07, 2015 6:30 am
Just cut a hole and put a big scoop on the bonnet
Post Posted: Fri Aug 07, 2015 6:34 am
jono165 wrote:
My engine is bolted in with the engine mounts that come in the low range offroad conversion kit. They were sold to me separately.
Post Posted: Fri Aug 07, 2015 8:05 am
Sorry, missed that bit. Will look it up. Thanks.
Vehicle: Suzuki Sierra Lwb
Post Posted: Sat Aug 08, 2015 10:22 pm
If you adjust the latch right up space the rubber stops on the corners and lift the bonnet at the bolts also oblong the holes a bit to gain some more. Other things o done was trim the area around the idle screw so its flush and remove the bracket and screws from the front of the intake manifold.
Hope it helps mine is the ben T kit with no body lift
Vehicle: 91 WT 1.6EFI
Post Posted: Sun Aug 09, 2015 6:10 pm
i got petroworks mounts from the USA, they drop the engine two inches.
Users browsing this forum: No registered users and 130 guests
