It is currently Thu Oct 22, 2026 12:32 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3
Post Posted: Wed Oct 28, 2015 10:59 pm
No need for chassis extension with sierra ruf just redrill the rear hanger bolt hole 20/25mm or so.
Post Posted: Thu Oct 29, 2015 6:42 am
Go back to page 1 of this thread for help on RUF
Vehicle: suzuki jimny 2007
Post Posted: Thu Oct 29, 2015 7:38 am
I read all there is out there about ruf
just thought that CJ springs are longer, but not as long as YJ's so i thought they would be good.
better articulation and better ride...
Post Posted: Sat Oct 31, 2015 6:33 pm
another question...
which tire size is better?
33/10.5/15 or 235/85/16?
can the samurai rear axle live in peace with the 33's?
Post Posted: Sat Oct 31, 2015 7:32 pm
33 10.5 has a lower load rating and more sidewall. If it's super slippery the added ground pressure of the narrower 235 will work better.
I'd run 33 10.5, but I run stupid tyres so I might not be the best judge. I do also like 235 85's.
Post Posted: Sat Oct 31, 2015 7:53 pm
33x10.5 better offroad but more likely to bust stuff and possibly be heavier sucking more hwy power
Post Posted: Sat Oct 31, 2015 9:44 pm
thanks guys! i will stay with the 235/85R16...
what about the front suspension? do you think that CJ's in front will make an improvment comparing to ruf?
Post Posted: Sat Oct 31, 2015 10:22 pm
No. Not enough to justify the chassis extension, loss of approach angle and hassles with wrap/dive caused by running a spring that long de-rated far enough to work on the front of a Sierra.
Post Posted: Wed Nov 04, 2015 6:07 pm
hi everyone...
thanks again for your answers...i learn a lot from you guys!
this is how my rig looks now...preatty awful IMO...
will update when have something worthy
Post Posted: Thu Nov 05, 2015 12:43 pm
Needs more lift =P
Post Posted: Sat Dec 05, 2015 2:17 am
Hello everyone again...
th eproject is going on... a lot of gear i ordered from Low Range and trail tough has arrived.
but i do have second thoughts on the tyre size...
is it true that with 235/85/16 the wheel bearings wont last long? in a matter of 3 monthes...
will 31's will be easier for the bearings?
Post Posted: Sat Dec 05, 2015 6:21 am
No that is not true. Tyre width and rim offset has more effect on wheel bearing life than diameter.
235's are narrower and go on a narrower rim= better for bearings.
Post Posted: Sat Dec 05, 2015 9:23 am
im running 31x10.5's on 15x7 -38mm rims and it's been about 1.5 years since my wheel bearings were replaced. Though the drivers side required a tighten up just recently.
Post Posted: Sat Dec 05, 2015 3:58 pm
60,000kms on my 235/85 with 2" spacers
Post Posted: Sat Dec 05, 2015 5:05 pm
Roger that! thanks guys...
Post Posted: Mon Dec 07, 2015 10:28 am
Driving in mud will kill them before the tire will
Users browsing this forum: No registered users and 149 guests
