It is currently Thu Oct 22, 2026 1:07 pm
Vehicle: Suzuki Sierra
Post Posted: Tue Jan 05, 2016 12:31 pm
Anyone ever had to swap a rear hub seal before? And if so can you give me a rough idea how to do it? Would be much appreciated
Post Posted: Tue Jan 05, 2016 12:35 pm
Huh? There's no such thing.
If you mean an axle seal, it's an easy remove and replace job, assuming the cause for seal failure isn't a failed wheelbearing or damage to the seal surface on the axle sleeve.
Post Posted: Tue Jan 05, 2016 3:43 pm
But I've ordered one, so it has to be a thing
Post Posted: Tue Jan 05, 2016 3:52 pm
A rear hub seal? O.o never heard of that.. As Steve said, might be an axle seal? In that case its easy.. Just work your way inwards past the hub until you got the axle, remove the axle pop out seal replace and go in reverse..
Post Posted: Tue Jan 05, 2016 6:53 pm
When you find a rear hub take a photo.
Post Posted: Tue Jan 05, 2016 8:08 pm
righto than thanks guys
Post Posted: Thu Jan 07, 2016 12:57 pm
Hope the pic works, this is the rear axle assembly and axle housing assemblies. Which bit are you referring to?
In the first pic, the axle seal is item 7. Seems like this would most likely be the bit your referring to. If you've ordered a bit over the net can you post a link to it?
Post Posted: Fri Jan 08, 2016 2:10 am
#7 is the seal protector - the seal is #6
Post Posted: Fri Jan 08, 2016 5:50 am
I was going to say the same thing, but it's a while since I've played with semi float rear axles and the picture isn't the best.
Post Posted: Fri Jan 08, 2016 9:36 am
Right you are ol son :)
Users browsing this forum: No registered users and 143 guests
