Vehicle: jimny
Posted: Mon Jan 11, 2016 7:51 am
Thinking of fitting a G16b engine from a baleno into my jimny and just wondering apart from the adapator kit what other mods need to be done ... cheers
Vehicle: 2000 Jimny
Posted: Mon Jan 11, 2016 6:36 pm
as steve said do a search, tons of info on it & if you aren't willing to research it a bit you probably shouldn't undertake it.
short list; - cam ring or cam will need to be swapped - brackets will need to be cut &/or ground & drilled - injectors will need to be swapped - longer belt & some hoses used - oil pick up cut & welded - possibly drill & tap a crank bearing cap
probably a lot of other little things i can't recall.
Users browsing this forum: Google [Bot] and 169 guests
