It is currently Thu Oct 22, 2026 12:30 am
Vehicle: jimny
Post Posted: Mon Jan 11, 2016 7:51 am
Thinking of fitting a G16b engine from a baleno into my jimny and just wondering apart from the adapator kit what other mods need to be done ... cheers
Post Posted: Mon Jan 11, 2016 8:05 am
Tried a search? I think there might be a couple of threads about this in the good tech section.
See what you can find
Vehicle: 2000 Jimny
Post Posted: Mon Jan 11, 2016 6:36 pm
as steve said do a search, tons of info on it & if you aren't willing to research it a bit you probably shouldn't undertake it.
short list;
- cam ring or cam will need to be swapped
- brackets will need to be cut &/or ground & drilled
- injectors will need to be swapped
- longer belt & some hoses used
- oil pick up cut & welded
- possibly drill & tap a crank bearing cap
probably a lot of other little things i can't recall.
Users browsing this forum: No registered users and 150 guests
