You can wrap the strap around the bar itself, then loop it through, just make sure it's in the middle. I prefer this over using a shackle personally.
OTHERWISE... get a properly attached recovery hook installed. This will involve welding additional gussets and plates to the chassis, but is by far the safest if done properly.
So far as being recovered, don't use the factory tie down at the front for anything other than flat towing. Mine took a whole bunch of snatches and what not but there's also instances of them breaking a weld or ripping the tube they're welded to. Again, you're best to have a proper recovery point fitted.
Users browsing this forum: No registered users and 76 guests
