It is currently Tue Jul 28, 2026 12:44 am
Post Posted: Tue Nov 01, 2016 3:22 pm
Hi all!!
Looking at the long ranger tank for my LWB Sierra project however I'm having trouble locating which model (if any of them) will fit.
My Sierra is a LWB body back with rear seats. '85 1.3
Options: according to Long Ranger they produce the TR07 which is for "all LWB model Utes", or the TR20A for all SWB models.
Im trying to get an answer from them, haven't managed yet, which one should fit my jalopy.
I'm guessing the LWB tank they produce is to suit the tray back version with the tank mounted on the left side beneath the front of the tray and the SWB will (rear mounted tank) will suit my tub. Can anyone confirm?
I don't know if any differences in the tanks, mounts, fillers, or space in which they fit between the SWB sierras and my LWB body back. Do you?
Has anyone got the long ranger tanks and have feedback or thoughts on them?
Cheers y'all!
Post Posted: Tue Nov 01, 2016 3:29 pm
i know our fuel tank guards for swb fit all sierras including maruti if that helps
Post Posted: Tue Nov 01, 2016 3:31 pm
Got a bodylift? Rework the mounts for a vitara tank
Cheaper
More common
Larger than a sierra
You'll be able to find a longrange second hand tank, They come up every now and then.
A new one is probably worth as much as your Sierra.
A LWB Sierra with a tub runs the same tank as a SWB.
Trayback Ute Sierra, Different
Trayback Maruti Sierra, (Cut tub) Same as LWB and SWB Sierra
Post Posted: Tue Nov 01, 2016 3:39 pm
Thanks mate!
No I'm not intending to run body lift. Is it a SWB vitara tank (I know little or nothing about Vits)? What sort of work to the mounts?
Yeah they're X'y, but I'm throwing heaps of cash at this project. Full rebuild and do it right.
So a SWB long ranger tank would be the one to opt for if I go that way?
Post Posted: Tue Nov 01, 2016 3:45 pm
LWB styleside and SWB tanks are the same.
SWB 1.6 Vitara tanks have the same capacity as a Sierra tank.
Post Posted: Tue Nov 01, 2016 3:48 pm
Thanks Steve
Vehicle: 2020 Vitara Turbo
Post Posted: Tue Nov 01, 2016 9:59 pm
Twin sierra tanks ! 1 each side of the exhaust !
( have been contemplating this with mine, could make mounts and get it to work )
Post Posted: Tue Nov 01, 2016 11:11 pm
Several people (including QLD or NSW rail?) have fitted trayback Sierra fuel tanks into longbody Sierras to give twin tanks. Personally I'd look at a Jimny tank, then the fuel filler is on the same side as the other, they're much easier to find and they have an inbuilt EFI pump. No idea if it will actually fit but it must be very close. Both are 40l. I'm sure you'd have no trouble sourcing the Landcruiser dual tank solenoid/s or you could pump from one tank to the other.
Custom brackets required of course.
I've seen a few longbody specific long range tanks on gumtree/facebook over the years that are 90l.
Vehicle: WT sierra, GU CRD
Post Posted: Tue Nov 01, 2016 11:43 pm
My ex QLD rail had a longranger tank. The thing was huge, I'd say around maybe 80 litres plus.
Wish I kept that thing and sold the SWB sometimes.
I love ZD30. :)
Post Posted: Wed Nov 02, 2016 8:34 am
Was that a trayback or extended body Marko?
Some good ideas Sideways and RexH!! Food for thought..
Post Posted: Wed Nov 02, 2016 12:17 pm
Markos was a long body. :)
Post Posted: Wed Nov 02, 2016 1:47 pm
Yep mine was a NT LWB style side.
I love ZD30. :)
Post Posted: Wed Nov 02, 2016 9:17 pm
I have a Lwb with a longrange tank. The thing is huge. I think it's 90L. I can take some pics of it tomorrow if you like?
Post Posted: Wed Nov 02, 2016 10:24 pm
That would be sensational!! Thanks!!
Post Posted: Wed Nov 02, 2016 10:25 pm
I think the SWB version is 70ltr, LWB is 80
Vehicle: 98 sierra coily
Post Posted: Thu Nov 03, 2016 7:11 am
I have a 70l long Ranger on a Swb that I'm wrecking out soon. Chasing 600. Located on the Gold Coast.
Post Posted: Thu Nov 03, 2016 7:40 am
http://imgur.com/a/P0YgV
Post Posted: Thu Nov 03, 2016 7:41 am
Post Posted: Thu Nov 03, 2016 8:08 am
Looks good!! Will keep an eye out for the ad [emoji4]
Post Posted: Thu Nov 03, 2016 9:18 am
Here are the pics of the longrange tank I have in my LWB. The previous owner said they used to get about 800 Km range out of it.
This is where the tank is mounted to the chassis.
Post Posted: Thu Nov 03, 2016 10:28 am
That is different to how mine mine was.
Mine IIRC ran along the length of the car forwards of the rear axle housing. Stock tank was retained. A fuel pump pumped fuel into the original tank when desired with a switch on the dash.
I love ZD30. :)
Post Posted: Thu Nov 03, 2016 12:27 pm
Ah righto, so they bolt up to the chassis rather than their original tank mounts.. easier to do while it's bare chassis!!
Might consider which way to go. They said they could make one up that has a heavy duty bottom, help reduce tank damage. That is a bit appealing
Post Posted: Thu Nov 03, 2016 12:39 pm
That'd be the way to go out bumsteins way. 80l mid tank, 90l rear!
Inb4 everyone cries about GVM.
Post Posted: Thu Nov 03, 2016 3:13 pm
Geez I'd get to Darwin and back!!! Might be exceeding max takeoff with 170kg of fluid slung underneath.. stiff springs and a Freightliner clutch should fix that lol
Post Posted: Thu Nov 03, 2016 3:22 pm
I had a Brown Davis 75L (approx) tank in my green LWB. Bolted in with a little modification (small grind) to the front most mounts. Exhaust had to be changed.
Post Posted: Thu Nov 03, 2016 5:43 pm
I have heard reports of the holden jackeroo 80l tanks being a very nice fit inbetween sierra chassis rails.
My understanding with the lingrangers is they mount poorly and force you to cut of existing tank mounts and attatch via ubolt type setup on the factory tube the tank mounts are welded to
Post Posted: Thu Nov 03, 2016 9:22 pm
The Jackaroo tank is to tall for a longbody but they fit great in a trayback.
Post Posted: Sun Nov 27, 2016 5:09 pm
Sorry mr bumstien looks mine is coily model tr48. Would foul on the leaves by the look of it.
Post Posted: Sun Nov 27, 2016 9:24 pm
Yeah thanks kenzook!! I saw your ad but figured the same.. still considering my options but have plenty of time!!
BTW, Mr bumstein is my father.. you can call me bumstein or 'the bum'.. eithers fine :D
Post Posted: Sun Nov 27, 2016 10:41 pm
Or bumstain :lol:
Users browsing this forum: Google [Bot] and 370 guests
