It is currently Wed Oct 21, 2026 3:21 am
Vehicle: 2002 Suzuki GV
Post Posted: Mon Nov 21, 2016 11:40 pm
Now I'm pretty sure this question gets asked a lot but I haven't found any recent threads on here about 1998 - 2005 GV rims and aftermarket rims that will fit, from what I've found so far it's mainly just the offset that stops the rims from fitting (because suzuki likes to be difficult :lol: )
However I just found a car on gumtree with some sunraysia rims on it? Check it out and give us your thoughts about fitment etc. I already sent the guy a message about where he got them from, hopefully he'll answer
http://www.gumtree.com.au/s-ad/bray-par ... 1130307439
My 2002 GV: viewtopic.php?f=4&t=53035
Post Posted: Tue Nov 22, 2016 5:33 am
The white one in that pic is klutched a member on here. He probably has the same rims. dynamic stee rims.
Post Posted: Tue Nov 22, 2016 7:39 am
Awesome, small world aye!
Got a reply from the blokes selling
"16x7 Dynamic rims. -13 offset. Have to grind calipers the fit"
Don't really want to be doing stuff like that to the car though. Good thing my GV came with nice rims anyway :D
Post Posted: Tue Nov 22, 2016 8:52 am
Unless I'm mistaken, it's not the offset that causes the issue, it's the profile of the rim - offset makes it less of an issue.
Vehicle: Which one?
Post Posted: Tue Nov 22, 2016 1:03 pm
Absolutely it's that. The profile isn't quite right in order to clear the front calipers.
And yes, klutched ground down his calipers. I can't say I am personally a fan of that idea, though. It also stands out like dogs' balls if anyone was to take a wheel off and look at your brakes.
Post Posted: Tue Nov 22, 2016 3:09 pm
Too easy thanks guys
I'll just be painting my rims black because I've got the nice mags :D
Post Posted: Wed Nov 23, 2016 7:04 am
Wheel spacers are the easiest solution but are illegal. A 15x7 10p rim will fit with a 40mm wheel spacer so a 16x7 wouldn't need much to fit. Maybe a 25mm
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Thu Feb 23, 2017 7:13 am
So what is the standard offset on the steel rims?
Post Posted: Thu Feb 23, 2017 11:39 am
16x7 5p
Vehicle: On the lookout
Post Posted: Fri Feb 24, 2017 10:11 am
Standard Rim types including offsets for the GV:
215/65R16 98T 7Jx16 ET5 ET 0-25 5x139.7
235/60R16 6.5Jx16 ET25 5x139.7
215/70R16 7Jx16 ET4 5x139.7
225/60R17 7Jx17 ET4 5x139.7
Source - www.wheel-size.com
What do you want to achieve with the new rims? larger diameter tyres for ground clearance? Fatter tyres for mud? Fatter is hard on the GV to achieve without scrubbing. But larger diameter isn't too hard if you select a tyre with a rounded profile like a Bridgestone Dueller 689 for example. But it'll be rubbish on anything other than Highway or Sand.
Crispy old grand vitara
Post Posted: Fri Feb 24, 2017 11:57 pm
Ummm - an SQ series GV with 17" rims standard? Not to my knowledge and my parts catalog does not have any numbers for a 17" rim on that model.
Post Posted: Fri Mar 10, 2017 12:08 am
This issue is, IMHO, the biggest PITA regarding the SQ series cars. Next to impossible to find a rim that will fit over LWB brakes & provide something usefully different from the Std 16 x 7 rims - all 5door wagon & XL-7 in Aust, had 16 x 7, as far as I have been able to find out & I've tried & tried to come up with something.
There is one steel rim design (5 oval holes) & 5 alloy rim designs (including XL-7) but they are all the same 16" x 7" & same offset.
This restricts tyres unless you get crazy with a grinder to either the bodywork, or as mentioned, the calipers.
225/75R16 is a comfortably nice fit with a little bit of suspension.
245/75R16 or 215/85R16 will have clearance issues & chassis rub, but manageable with a bit perseverance & care.
Rgs, Michael
Post Posted: Mon Mar 13, 2017 2:14 pm
Chassis rub is easy to fix . Just add rack limiters on the rack. Its juat a plastic shim that clips on behind the rackend. I know ford sell them overseas so they might in aus. Dont know if they fit but a aftermarket one might.
Users browsing this forum: No registered users and 138 guests
