It is currently Sun Jul 26, 2026 8:33 am
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sun Feb 19, 2017 9:38 am
After breaking my draglink on the first round in mod class off TT yesterday l think it is time to revisit and beef up the steering.
I have a Pajero steering box with balljoint, custom draglink and standard tierod.
So l can make a stronger draglink which will need to be eye to eye ends or make a whole new setup
What's your thoughts?
Post Posted: Sun Feb 19, 2017 2:45 pm
Yes it was a shame it broke. We had lots of spares but not for your mods.
Hope you find an answer.
Now onto my repairs on Casper. ;-)
Post Posted: Sun Feb 19, 2017 3:17 pm
What happened to Casper?
Thinking of either going to hilux cruiser steering components or heir joints. Th big issue is the angle from the pitman arm and if l keep it the same l need to go eye to eye again
Post Posted: Sun Feb 19, 2017 3:48 pm
Did rear short axle at the 800 point on track 3. Also did steering arm at same area.
Post Posted: Sun Feb 19, 2017 5:09 pm
Well l found a spare eye from th prototype l made so l can get wheeling again quick sticks but I still think I will upgrade the steering a bit
Post Posted: Sun Feb 19, 2017 9:05 pm
I'll have rods similar to what Twin stick had in the not to distant future for those interested
Post Posted: Sun Feb 19, 2017 10:16 pm
My custom made steering kit (high steer) is some weird alloy the engineer specified (not crmo, something else i can't remember) and about 20mm dia. I'm only running 31's but the steering has taken a beating and still goes great.
I reckon just_cruizin's solution is likely better than trying to frankenstein something.
Post Posted: Mon Feb 20, 2017 6:41 am
JZ got any specks of what you are looking at making.
I think the main issue with mine is binding up due to the limited movement in the balljoint on the pitman arm.
Post Posted: Mon Feb 20, 2017 8:28 am
I remember reading something a while back about reaming out the steering arms and putting hilux or cruise gear in upside down. This would get rid of the angles as well
Post Posted: Mon Feb 20, 2017 11:29 am
Low Range Off Road offers a reamer for that purpose - allows the use of FJ80 ends.
Post Posted: Mon Feb 20, 2017 11:38 am
i have one of those reamers Gav
Post Posted: Mon Feb 20, 2017 12:21 pm
Did you do it the same as or inverted when you modded it and how hard was it?
Post Posted: Mon Feb 20, 2017 12:35 pm
i just reamed the same way up.
you use a mixture of 80 series and 70 series tie rod ends and make the rids to suit
Post Posted: Mon Feb 20, 2017 12:38 pm
in this kit you need the fair right one and the far left one. These replace the part you broke on the weekend. the relay part. then the normal ball joint at the bottom you need two of to replace the ends
http://www.ebay.com.au/itm/Tie-Rod-End- ... SwNnRYheNQ
Post Posted: Mon Feb 20, 2017 4:45 pm
Thanks Darren
Did you have much trouble reaming them out?
Post Posted: Mon Feb 20, 2017 4:47 pm
nah, couple of mins each with the reamer in a drill
Post Posted: Mon Feb 20, 2017 4:50 pm
great
Post Posted: Mon Feb 20, 2017 5:35 pm
I run a hiem with misalignment spacers on my Toyota box and it use to be a stock TRE on the other end when it was Zook diffs. I have to keep an eye on the bolt and have got in the habit of giving it a little nip up before each trip to make sure its still tight.
Made in JP. Built in WA.
Post Posted: Mon Feb 20, 2017 6:14 pm
We were looking at that idea as well but will depend on whether I can get a pitman arm that will fit the pajero box that has an eye not a ball joint.
Post Posted: Wed Feb 22, 2017 6:46 pm
Progressed my kits today, arms are underway. Rods end are Landcruiser components. Arms will be 4340. I'm planning on either running a knuckle and steering arm exchange or including reamers in the kit
Post Posted: Wed Feb 22, 2017 6:55 pm
Price wise looking at about $550
Post Posted: Wed Feb 22, 2017 8:12 pm
I just ordered a 40 series kit that should have all I need. I did order the reamer from Superior but they are telling me a 3 week wait.
I will just need to work out the rods in between, not sure whether to modify Toyota gear or fabricate myself, then there is the choice of solid or tube and chromo or not
Post Posted: Thu Feb 23, 2017 8:11 am
your welcome to borrow my reamer gav
Post Posted: Sat Feb 25, 2017 6:13 am
See how we go with time Darren, thanks for the offer
Users browsing this forum: No registered users and 41 guests
