It is currently Sat Aug 08, 2026 1:39 pm
Vehicle: 1995 Suzuki Sierra SJ70
Post Posted: Fri Jun 23, 2017 12:59 pm
Another noob type question here.
Where is the second Baleno engine lift point?
I can only see 1, highlighted in purple below.
I actually want to remove the engine minus the transmission if possible.
The FSM only explains how to remove them both together.
Assuming I just undo the transmission to engine connections and push them apart as I hoist out the engine.
Post Posted: Fri Jun 23, 2017 1:33 pm
I just run a strap around the back of the head/ thermostat housing. It's not a heavy motor.
Post Posted: Fri Jun 23, 2017 3:44 pm
I just double up a tiedown strap through the exhaust and inlet manifolds
Post Posted: Fri Jun 23, 2017 5:31 pm
I decided to remove one of the lift points from the sierra 1.3 block and then attached it to the inlet manifold on the Baleno.
Seemed to hold pretty firm. Got it out and onto a pallet now!
Users browsing this forum: No registered users and 70 guests
