It is currently Thu Oct 08, 2026 7:59 pm
Vehicle: Suzuki Jimny
Post Posted: Fri Aug 11, 2017 6:27 pm
LOOM SWAP
Complete swap including the stalks
91 Lwb Jx g16b (auto) to a sj51 g13
What are the issues with swapping to a manual from the donor auto?
Anyone got wiring diagrams etc or a guide or doing the complete swap
Thanks
Post Posted: Sat Aug 12, 2017 9:18 pm
Help....... me.......
Post Posted: Sat Aug 12, 2017 10:26 pm
Keep the auto.
Post Posted: Sun Aug 13, 2017 6:49 am
Want to keep the original g13 manual
Auto gearbox is stuffed
Post Posted: Sun Aug 13, 2017 7:44 am
Just slap it all in and use a simple relay to power up the ignition on the vit loom to match the sierra igntion signal.
If you try strip it all down with no idea theres every chance you will stuff it. Suzistore and suzishop in the west will do a cut down labelled vit loom
Post Posted: Sun Aug 13, 2017 8:48 am
Okay how about...
Using the entire loom apart from the auto plugs
Is there any difference considering the gearbox is not electronically controlled
Vehicle: Sierra g16 efi..and Sierra GTi
Post Posted: Sun Aug 13, 2017 10:02 am
You need to get a loom made... We have a 1.6 conversion and it was a PITA.... The new tagged loom was a "must have"!!!!
Post Posted: Sun Aug 13, 2017 12:54 pm
The ecu for the auto box is seperate so in short yes you can run the auto loom with a manual. I know on balenos the ecu is the same for both box configurations.
I wouldnt say a cut down loom is a must have, if planning on cutting the loom yourself it can be benifical to install a full loom to remove any troubleshooting issues initially and then begin chopping
Post Posted: Sun Aug 13, 2017 7:54 pm
Perfect took the whole thing out today
Seems to be about 3 ecu type things
Users browsing this forum: Google [Bot] and 226 guests
