It is currently Mon Oct 19, 2026 11:41 pm
Post Posted: Wed Oct 07, 2020 3:12 pm
Hi all.
Hoping someone has a similar set up and can help me out.
Vitara with calmini 3" suspension kit, including Lower arms. No body lift....
How much bump stop spacing will I need to stop a 235/85 R16 from killing itself on my guards? Front only.
This is a temporary measure until I can do a virtual lift.
Firewall and back of guards, as well as headlight buckets have been trimmed to within an inch of their lives already.
Running XL7 rims.
Cheers.
Post Posted: Wed Oct 07, 2020 3:13 pm
Worth adding... suspension is apart already, so a flex test is a little difficult.
Vehicle: Suzuki Vitara 94 LWB
Post Posted: Thu Oct 08, 2020 8:20 am
In mine with no body lift on 31s I had 50mm bump stop spacers and even then I could get the tyre to hit the the guard and all the weight was on that wheel.
Post Posted: Thu Oct 08, 2020 11:34 am
Yeah ok.
Cant have had much usable up travel. Ill start at 50mm and add what I need from there.
Post Posted: Thu Oct 08, 2020 11:43 am
50mm at the bump will be 100mm at the wheel. A stock vitara barely has 50mm between the bump and the a arm.
Post Posted: Thu Oct 08, 2020 11:47 am
How much of the overall length of the oem rubber bump stop actually compresses under heavy load?
Post Posted: Thu Oct 08, 2020 11:49 am
I’d work on 50%
Post Posted: Thu Oct 08, 2020 12:19 pm
Working on that.... 65mm spacer is needed.
Post Posted: Thu Oct 08, 2020 12:26 pm
CJ ran a vitara calmini kit with 7.50’s on steel 2.0/V6 vitara rims, no BL, and had no/minimal tyre contact. That’s about as much help as I can offer.
If it ran bumpstop spacing at all in the front it was only the XL-7 shim.
Post Posted: Thu Oct 08, 2020 12:28 pm
Post Posted: Thu Oct 08, 2020 12:33 pm
This is almost full extension. Maybe 5 or 10mm left in it.
About 165mm total travel left. I can live with that for now.
Id wager I would have needed an extension anyway as I reckon those calmini springs would bind before touching the oem bumps
Post Posted: Thu Oct 08, 2020 1:04 pm
Yes, I’d agree with that- I believe the coils bind at full compression. I think the wider track of the 2.0 litre car along with the XL-7 rims are complicating things as they tyre can’t tuck inside the guard.
Post Posted: Thu Oct 08, 2020 1:12 pm
Check Shandy92's build thread?? He was running 31s with some franken-lift, but there might be some info there, even if just in images?
Post Posted: Thu Oct 08, 2020 1:52 pm
Not pleased that I'm reducing travel, but here's what a 65mm spacer looks like.
Hoping to get this down to 25mm or so after a virtual lift in the future.
Steve- agree about the extra width giving me clearance issues.
Alien- ill check it out. Thanks.
At this stage I think the only cure would be smaller tyres or less panels.
Users browsing this forum: No registered users and 250 guests
