It is currently Fri Jul 24, 2026 3:50 pm
Vehicle: Suzuki sierra SJ413
Post Posted: Sat Oct 31, 2020 9:20 pm
Hey all, looking at what gears to run, I'm running 31x10.5, go 4wding every second weekend or so but the Zook is my daily driver to and from work. mainly hill climbs, technical stuff, mud etc., rarely beach driving unless putting tinny in. Was looking a some 6.4.1s from sumo gears, anyone running these? or recommend anything else? will the revs be high and will this will restore power back in 5th gear correct? if so i should easily get to 100 if not 110? all stock engine, sj80, will be getting new exhaust system 2 inch along with headers and maybe upgrade carby soon.
Cheers all
Vehicle: 89 suzuki sierra
Post Posted: Tue Nov 03, 2020 6:02 pm
I may be wrong but I am pretty sure 31's are to big legally to run on an sj80, but yeah 6.5s or 6.4s will deff help, I use to run 31's on my sierra but the boys in blue suggested I go down to 30s. just my 2c worth
Post Posted: Tue Nov 03, 2020 7:10 pm
The gears help but with 31"s its never going to drive like its running 29"s or 30"s. There will still be many an occasion especially in a strong headwind or an incline where 5th is just a distant memory.
With a 1.6 swap this becomes a non issue
Post Posted: Tue Nov 03, 2020 8:29 pm
Mine ran 5.14 & EFI 1.6 and was spot on both on and offroad with 31's.
Post Posted: Tue Nov 03, 2020 8:45 pm
cheers all, yea heard about it still slowing done on hills etc.. plans to engine swap in future... and with the higher gearing, Id want to invest in chromo axels correct? i know you can get them for the rear, but what's the go with the front? do i have to change the front diff? both?
Post Posted: Wed Nov 04, 2020 2:40 am
Im assuming your front is locked ?
No point upgrading axles at all up front unless your locked.
Unsure on coily weirdness but sierra chromos are generally 26 spline meaning you need the side gears out of a rear diff if you have a lockrite or you need to order a rear air locker for the front to match the 26 spline axles.
Ive never had an issue in the rear running 32" tyres on standard axles. The only people ive known to have dramas are those who upgrade the rear axles to hd (seem weaker than stock) or those who go to a full float diff setup.
Post Posted: Thu Nov 05, 2020 6:52 pm
Cheers, nah neither diffs are locked atm
Post Posted: Fri Nov 06, 2020 8:39 am
I’ve broken two stock semifloat axles on 34” Swampers. I don’t believe upgraded rear axles are required at 31”.
Post Posted: Sun Nov 08, 2020 11:33 am
Yea okay thanks
Users browsing this forum: Google [Bot] and 371 guests
