It is currently Sat Jul 25, 2026 7:01 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
Post Posted: Fri Oct 02, 2009 2:15 am
VERY NICE,gotta be happy with that. if only i had a few more $$$
Post Posted: Fri Oct 02, 2009 1:39 pm
Interested to see why this drop pitman arm wont fit AJSR, was thinking very seriously of getting one myself.
Appsie, I've finished the steering damper mounts, I'll get some photos up later today. It has eradicated the wobbles on one of my tyre sets, almost eradicated it on another, but done SFA for my alloys :roll: . So I think its worked somewhat, its just my wheels dont work :lol: .
Clearance Hole Technology :P
Post Posted: Fri Oct 02, 2009 3:04 pm
this will also depend on whether you have your diff moved forward much or not?
Post Posted: Sat Oct 03, 2009 2:40 am
thanks aaron will be good to see what you have come up with.Am keen on it.
Mine isnt too bad but i still wanna fix it 8) Am thinking mite respline my sierra arm or try something else.
Tanshi, i havent moved my diff at all,all stock as im lazy
Post Posted: Mon Oct 05, 2009 1:03 am
Appologies for my sluggishness with getting these on the net:
Basically the standard chassis end mount for the damper. The pitman arm end is a piece of steel that clamps around the pitman arm, and is a snug fit between the lump on the Vit arm and the colar on the foward end of the pitman arm.
Not sure its going to be permanant on my car, still need to sort it out properly.
Post Posted: Mon Oct 05, 2009 12:18 pm
I don't know fir sure whether the drop arm will bolt on a car with the front diff in the stock location, but I reckon it would have to be very close if it fits.
Basically, the arm is 17mm longer centre-centre than the stock vitara arm. The car we've fitted one to is RUF, with the steering box a full 40mm further forward than stock. It also has just over 2" of bumpstop spacing. We had to rotate the steering box more than we normally would when fitting a vitara box to get the arms to clear. The bottom bolt on the Vit box needs to be really close to the bottom of the chassis to get enough rotation.
Of course if you were building from scratch you could space the box forward enough to make it work, but as it is the drop arm isn't, AFAIK, a bolt in solution unless you are SPOA (and a tall, bumpstopped SPOA at that)
Post Posted: Mon Oct 05, 2009 1:36 pm
OK, thanks.
Considering my axle is about 17mm foward of stock, I would likely run into issues with that. Might have to do some lateral thinking, or chase up that Tarago arm Damo mentioned.
Post Posted: Mon Oct 05, 2009 2:40 pm
thanks for the pics aaron gives a few ideas for the time being.
Steve,as always your full of knowledge :lol: thanks for the help.The torago arm does seem like a good option and shouldnt be too hard to find id think.
If not jimny arm??same spline i believe a little less drop than stock sierra and just shorter centre to centre so would affect the steering a little but is still a option?
Post Posted: Mon Oct 05, 2009 2:41 pm
howd you go ajsr?
Post Posted: Mon Oct 05, 2009 2:46 pm
Just remember you will need to do something about the taper in the end, a stock Sierra TRE wont just bolt in there.
Post Posted: Mon Oct 05, 2009 2:52 pm
yeh thats cool i could machine up a little taper at work to slip in there
so does anyone know a definate on the jimny arm fitting the vit box?Or do as steve(oozook) done and respline stock sierra one?
Vehicle: '92 Sierra
Post Posted: Mon Oct 05, 2009 3:20 pm
Here's some pics of mine with half RUF and a calmini dropped pitman arm. I think they run a 2 inch drop As I mentioned earlier I had to clock the box to suit after it wouldn't clear the tie rod. As you can see the drag link and tie rod are practically in the same plane so no bumpsteer.
Users browsing this forum: No registered users and 50 guests
