It is currently Sun Oct 18, 2026 11:02 am
Post Posted: Mon Aug 04, 2025 8:44 am
Hello Team,
I have a 1992 SWB vitara. The Tacho is not working, and I am considering an after market tachometer. Where is the pulse pick up located on this model? ECU or coil?
Pete
Post Posted: Mon Aug 04, 2025 11:44 am
I assume you have a TBI 8v model, Australia didn’t receive that model so local experience will be patchy. I suspect it will be off the coil as per the carb version.
I’d determine why the stock tach isn’t working- it might be a simple fix.
Post Posted: Mon Aug 04, 2025 1:10 pm
Hello Steve,
It is a 16v injected model. I have swapped out the tacho head foe another, but no go. I thought I may be able to check if there is in fact a pulse from the source also. Some info says it originates from the the radio suppressor at the coil. Not sure what that looks like though.
Pete
Post Posted: Tue Aug 05, 2025 5:13 pm
Yes, tach signal is brown with a white trace from memory.
Users browsing this forum: No registered users and 308 guests
