It is currently Fri Jul 24, 2026 9:05 pm
Post Posted: Tue Oct 20, 2009 6:31 pm
well when i get a new diff housing, if i get a job... lol.. i will have to set up my mounts and everything on it again.
i was just wondering if jimny springs are different left and right in the front to make up for the lean ? or do jimny's not have a lean ?
anyways i had to make one coil seat higher than the other to make up for the lean in my coily when i set up the seperate coil and shock. and i actually had to put a 15mm spacer later on aswell :?
thoughts ?
Vehicle: Currently vehicle-less
Post Posted: Tue Oct 20, 2009 7:02 pm
yea there is a difference in lengths for sure, not sure as to how much though. I actually thought from memory that the spring lengths may have been same in front - with a longer drivers rear, however I cant remember now
Post Posted: Tue Oct 20, 2009 7:42 pm
same front lengths, different rear lengths.
Post Posted: Tue Oct 20, 2009 8:22 pm
hmm any thoughts on what my other options could be, probably no way of telling if jimny rears would work..
Post Posted: Tue Oct 20, 2009 9:48 pm
you've done coils before joe how do you deal with the lean ?
Post Posted: Wed Oct 21, 2009 9:23 pm
ideas ?
Post Posted: Wed Oct 21, 2009 10:38 pm
Urethane spring spacer on the heavy side? I've run urethane spacers on the heavy side of my Gwagen fo 10 years and it's been fine.
Post Posted: Wed Oct 21, 2009 10:56 pm
known as 'trim packers'. most 4x4 shops will sell em and i do believe arb make em for jimnys.
Post Posted: Thu Oct 22, 2009 2:07 am
ah okay so there are no issues with my current setup then :) ! was not sure if the suspension guru's thought of this as a no go.
Users browsing this forum: No registered users and 651 guests
