It is currently Sat Oct 24, 2026 4:36 am
Vehicle: Work van
Post Posted: Tue Mar 29, 2011 7:34 am
Okay so this is sort of a Suzuki question as I have lux diffs in my zook.
I have a welded front diff and an open rear centre, I have bought an air leaker and was wondering if someone could tell me if the front and rear centres are interchangeable, as I would prefer the air locker in the front rather than the back.
Thanks in advance for the help :helloo: :D
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Tue Mar 29, 2011 7:38 am
and you'd prefer the Welded diff in the rear???
Stocker
Vehicle: Work van
Post Posted: Tue Mar 29, 2011 7:41 am
More than the front, will only be for a short while until I get another airlocker :D
Post Posted: Tue Mar 29, 2011 8:01 am
i see...
i'd still put the thing in the back... at least your axles will thank you when you put the 2nd Locker in the front
Stocker
Post Posted: Tue Mar 29, 2011 8:10 am
Front and rear lux diffs are interchangeable....
Vehicle: Work van
Post Posted: Tue Mar 29, 2011 8:18 am
Cheers jas
Post Posted: Tue Mar 29, 2011 8:38 am
check this out
http://forum.darwin4x4.net/viewtopic.php?f=6&t=4834
he is also a AZ member
Vehicle: Work van
Post Posted: Tue Mar 29, 2011 8:47 am
Thanks shep I'll check that out after all the outgoings for the bills are paid and see how the funding is looking
Post Posted: Tue Mar 29, 2011 9:25 am
I just bought a pair of ARB lockers in 4.88 centres (one a hi pinion) for $1500.... A mate bought just an ARB locker for $250..
They are around AND cheap if you look hard enough....
Vehicle: Work van
Post Posted: Tue Mar 29, 2011 9:40 am
Is there any advantage to a high pinion diff? I picked up my arb new in box for 800, I have been looking for a second cheap one
Post Posted: Tue Mar 29, 2011 9:42 am
Where do you look for them?
Vehicle: Work van
Post Posted: Tue Mar 29, 2011 9:46 am
Other forums, i found mine by googling arb hilux locker :lol:
Post Posted: Tue Mar 29, 2011 9:55 am
i believe in a hilux they most certainly are 8)
Post Posted: Tue Mar 29, 2011 10:42 am
High pinion raises the tailshaft and gives a lot more ground/rock clearance....
80 series use hi pinion front standard....
Post Posted: Tue Mar 29, 2011 10:52 am
Hi pinion was designed so the gears use the stronger 'drive' side when placed in a front diff moving in the forwards direction. Placing one in the rear would mean you would be using the weaker 'coast' side when going forwards.
Users browsing this forum: No registered users and 134 guests
