It is currently Tue Sep 29, 2026 4:55 am
Vehicle: 2" lift, 215 a/t
Post Posted: Wed Nov 30, 2011 10:53 am
Hey guys I'm new the the forum and suzukis. Have had a few Fourbies before most recently a tj wrangler with lift, front and rear lockers, winch and all the usuals. Bought the Jimny to have as a cheap daily and keep the short wheelbase fun happening!
Basically as its a daily i don't know whether the 80mm lift would be too much? From readin the forum im looking at getting some 215/75r15s so that i don't need any gearing adjustments and not sure what's the best lift a 40mm,60mm or 80mm. Any advice would be greatly appreciated. I don't want to ruin fuel economy and general runabout drivability by lifting it too much. Would an 80mm tough dog behave ok on the road?
Post Posted: Wed Nov 30, 2011 10:58 am
Jimny bits 75mm lift, enough Said :D
Post Posted: Wed Nov 30, 2011 11:00 am
Also are all the jimnys the same in the way of suspension setup. Eg would a lift kit off an 01 fit my 06?
2" lovells lift, snorkel, 215/75/15 A/T's
Post Posted: Wed Nov 30, 2011 11:01 am
http://auszookers.com/index.php?name=Fo ... y+lift+kit
http://auszookers.com/index.php?name=Fo ... 83&start=0
2" lift and 215's!
monkey wrote:
3" lift is to big imo for any thing smaller than 30" tyres....that just me tho....mine felt very unstable on 235s with a 80mm lift....much better now with a 4" lift and 31s :p
I would hate to see how 215's and a 3" lift would feel on any sort of side angle....
Stock gearing is just livable with 235's...but you will lose some economy...
Post Posted: Wed Nov 30, 2011 11:03 am
The suspension has never changed on a jimny ie. The same lift that would fit a '98' model will fit a '2010' model :wink:
Post Posted: Wed Nov 30, 2011 11:05 am
Goes heaps good 8O Drive sensible and you shouldn't roll
Post Posted: Wed Nov 30, 2011 11:07 am
:crazy: 235's and a 80mm lift on15x7 -13 rim's felt tippy :helloo:
Post Posted: Wed Nov 30, 2011 11:10 am
Yes this is precisely what I was worried about. I wouldn't imagine 215s and a 2 inch lift would do much to the economy. What does everyone rate as the best and most versatile 215 for a Jimny. I'm after not an insane road noise but something that will do well off road also. Was thing bf Goodrich a/t 215s as they seem quite chunky for an all terrain. I've been a cooper discover man all the way but they don't make the ST in a 215 :-(
Post Posted: Wed Nov 30, 2011 11:47 am
I have km2s in 215s, they work well were I drive, also kumos kl71 I thing they are all so come in 215s.
Both of them really are no were near a all terrain but will perform pretty good offroad
Can't expect much for a swb vehicle :wink:
Post Posted: Wed Nov 30, 2011 11:49 am
Why not? Mine is rather stable, as is smiffkids....
Post Posted: Wed Nov 30, 2011 11:59 am
Just saying still will be tippy at some stage. Mines doesn't feel that bad nd I was on a slop, but I have no sway bar and Jimmy bits shocks are quite soft for my liking.
Vehicle: 09 Jimny, 3in lift & BFG's
Post Posted: Wed Nov 30, 2011 12:05 pm
I'm running 215s on the 3inch jimnybits and don't find it too bad on side slopes at all.
Mind you, I'm not out there blowing up reverse gears either.
Post Posted: Wed Nov 30, 2011 12:17 pm
I am only pointing out that a 3" lift(or 90mm JB lift) and 215's will be much more unstable than say a 2" lift with 215's....
What's the worst side angle/slope you have been on?
Post Posted: Wed Nov 30, 2011 12:21 pm
my cousin is running 215/75r15 BFG KM2 with no lift at all in his jim.. it scrubbed a little when brand new, but given 5000km they dont rub anymore =P
Post Posted: Wed Nov 30, 2011 1:21 pm
See, I don't agree. A 2 inch lift that has poor spring rates or is incorrectly dampened, can be more unstable than a 3 or more realistically 4 inch lift that has the right spring and shock rates for the vehicle's weight.
I agree that the jimnybits kit is somewhat overkill for a mild daily - that's what mine's supposed to be - but I feel more stable on this setup than the OME 40mm I drove a couple weekends ago.
Side slope was probably around 30 degrees at a guess, slippery Alpine clay and loose rock up past Licola. But driven carefully taking the most neutral line for pitch and roll, it felt pretty planted to me. You learn to cope with side slopes when your first fourby is a series landrover - those bastards are narrow and tall.
Post Posted: Wed Nov 30, 2011 6:47 pm
So what your trying to say having a higher COG is going to make the jimny more stable then having a lower COG? :roll:
Post Posted: Wed Nov 30, 2011 8:41 pm
Nope, what im saying is that stability isn't as simple as COG. spring rates and shocks mean every bit as much in managing stability as height. :helloo:
and driver sensitivity to all of these factors and how they work Together is the difference between staying upright or taking a nap.
Post Posted: Wed Nov 30, 2011 9:04 pm
No lift is "required" to run 215's.
Smaller lifts result in less compromised vehicle behavior.
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Wed Nov 30, 2011 9:33 pm
I am running 215 on a stock Vitara with no hassles. If I want 235 then I would need a 2" lift. The Jimny would be fine with 215 as from memory it has more clearance than mine.
I am getting a 2" lift for the crossmember clearance, not because of any tyre scrubbing problems.
Post Posted: Wed Nov 30, 2011 9:46 pm
5 inch lift and 31s on 15x8-28 offset going nearly as wide as u do high,
and handles well
just ask alien or andrew about my weekend antics
dodgy brothers mechanical
Post Posted: Wed Nov 30, 2011 11:10 pm
^^ he likes to do burnouts, and he hasnt rolled it yet =) lol
Users browsing this forum: No registered users and 143 guests
