It is currently Sat Oct 24, 2026 2:54 pm
Post Posted: Sat Mar 27, 2010 8:04 pm
I was cleaning the engine bay and noticed a hole in the trans box about the size of a 20 cent piece is it suppose to be there
Post Posted: Sat Mar 27, 2010 8:08 pm
What type of vehicle? Does it go right through or is it blanked off? Do you have pics? I would suggest it's probably just a casting for something that isn't used on your model.
Just re-read your post :roll: :lol:
It goes through to the flywheel? It's for checking the ignition timing and comes with a rubber bung that fits in it.
Post Posted: Sat Mar 27, 2010 9:12 pm
Heh yeh ScrawnC had to reread a few times too, i take it he means transMISSION not transFER. If its transmission than thats normal, if its transfer than youre in trouble.
Post Posted: Sat Mar 27, 2010 9:22 pm
That's where I ran into trouble as I'm usually just skim reading :lol: :lol:
Post Posted: Sun Mar 28, 2010 4:59 am
There is a hole in the left side of the bellhousing on Sierras and LJs that is the inspection hole for the ignition timing mark on the flywheel. There should be a rubber plug to fill the hole, but they sometimes get lost.
Post Posted: Sun Mar 28, 2010 5:42 pm
could that be why the clutch in not engaging because i had it submurged in mud could it be slipping on sumthing that has gotten into the clutch or flywheel
Post Posted: Sun Mar 28, 2010 11:37 pm
Could well be....
I want my old sig back :(
Users browsing this forum: Google Adsense [Bot] and 81 guests
