What type of vehicle? Does it go right through or is it blanked off? Do you have pics? I would suggest it's probably just a casting for something that isn't used on your model.
Just re-read your post
It goes through to the flywheel? It's for checking the ignition timing and comes with a rubber bung that fits in it.
Joined: Sat Oct 24, 2009 10:30 pm Posts: 845 Location: Melbourne
Posted: Sat Mar 27, 2010 9:12 pm
Heh yeh ScrawnC had to reread a few times too, i take it he means transMISSION not transFER. If its transmission than thats normal, if its transfer than youre in trouble.
That's where I ran into trouble as I'm usually just skim reading
There is a hole in the left side of the bellhousing on Sierras and LJs that is the inspection hole for the ignition timing mark on the flywheel. There should be a rubber plug to fill the hole, but they sometimes get lost.
Joined: Sun Mar 14, 2010 10:30 pm Posts: 54 Location: victoria
Posted: Sun Mar 28, 2010 5:42 pm
could that be why the clutch in not engaging because i had it submurged in mud could it be slipping on sumthing that has gotten into the clutch or flywheel
Users browsing this forum: Google [Bot] and 83 guests
