It is currently Mon Oct 26, 2026 4:01 am
Post Posted: Thu Apr 29, 2010 6:42 am
So the time has definitely come for me to replace the bushes in my control arms. I noticed last time I was at Glasshouse Mtns that I suddenly had rear steering... Not good.
I was going to wait until I could get a hydraulic press on sale but now I'm desperate. The back end is all over the place and I have a week to get it sorted.
Does anybody have any tricks for removing them without a press?
Also, where can I get non-genuine RUBBER bushes for a reasonable price?
Are Coily bushes definitely the same?
Post Posted: Thu Apr 29, 2010 7:25 am
You can cut them out. I used a jigsaw to remove mine a while back. Cut the inner tube, then slowly work out if that makes sense.
Post Posted: Thu Apr 29, 2010 7:39 am
A vice, big hammer & a cold chisel.
But you will be there for hour's. 8O :roll:
Post Posted: Thu Apr 29, 2010 9:27 am
Any ideas for where I can get the bushes? I got a price for 6 bush set of genuine bushes for $415
Post Posted: Thu Apr 29, 2010 11:25 am
I needed to use a 30 tonne press and a oxy to get mine out!
Post Posted: Thu Apr 29, 2010 11:34 am
:shocked: Press should of done the job, if thay don't move, leave around 5t on em & spray with WD40 or similer, then let em sit for a bit, oxy's not good for cast arm's.
Vehicle: 75 Cruiser
Post Posted: Thu Apr 29, 2010 11:36 am
you can drop in to my place and use my press if you need to nutter. Depends if you get a better solution or not.
Post Posted: Thu Apr 29, 2010 12:15 pm
may take you up on that. Thanks
Post Posted: Thu Apr 29, 2010 12:45 pm
yeah needed it done quick tho, doesnt matter as i dont have that jimny anymore :(
Post Posted: Fri Apr 30, 2010 8:05 am
Pulled the arms today. Here's some pics of the slightly worn bush.
after shopping around for bushes I've decided to make my own from wood :-)
Post Posted: Fri Apr 30, 2010 8:10 am
Wood flex's well!!! 8O 8O 8O
In a Friggin cyclone.
The bush's you hae are fine, haven't even started to wear the bolt's yet. 8O 8O 8O :roll:
Post Posted: Fri Apr 30, 2010 8:19 am
I'll use balsa.
Seriously though I am going to make my own from some two piece bushes. Hopefully it works out... We'll see!
Post Posted: Fri Apr 30, 2010 8:21 am
Have fun!!!
:P
Post Posted: Fri Apr 30, 2010 8:22 am
I bet you've seen some bad ones
Post Posted: Fri Apr 30, 2010 8:34 am
Every morning when I look in the mirror. 8O :roll:
had a guy get his xe towed in, he said it won't drive, must be the auto he thinks.
went out to look, see a drive shaft in the back of the wagon with a smashed up rear uni, asked where he got that, said he found it on the road when he broke down, asked if i wanted to buy it. 8O
I said he may need it.
Post Posted: Sat May 01, 2010 8:26 am
I made my bushes today. Will be making a few mods to them but for now just concentrated on getting the Jimny rolling again.
This pic shows the donor bush on the left, cut close length in the middle and finished, ground down and narrowed.
Post Posted: Sat May 01, 2010 9:35 am
:P :P
Very nice. :P
Post Posted: Sat May 01, 2010 9:47 am
Took about two and a half hours each side. I left the metal sleeve of the old bush in place for a bit of extra strength and just cleaned the rubber from the surface.
After having a good look at the factory bushes I can't help but think they are definitely a contributing factor in the wobble. Two small rubber spokes holding it all together. They were definitely designed with axle articulation in mind though.
Including burning out my drill with the wire brush total cost is $180.
Post Posted: Sat May 01, 2010 9:51 am
The new bush we replace is solid, but that goes in the leading arm.
The king pin shim has made the bigest diffrence that i can see, notice a tighter drive right away.
Post Posted: Sat May 01, 2010 9:58 am
Yeah shims made a big difference to mine. I'm pretty certain that the primary cause of the wobble is side-to-side movement due to a lack of lateral ridgidity in the control arm and panhard bushes.
Then again I've had a few theories along the way. One thing for sure is that there is combination of factors that should all be rectified for a permanent fix.
Post Posted: Sat May 01, 2010 10:00 am
is it the same as control arm-to-chassis bush?
Post Posted: Sat May 01, 2010 10:21 am
Yes, rear bush on the leading arm, I told Suzuki that I think thay make no diffrence to the wobble, I fitted them then drove it, then fitted the shim's.
On the next one I fitted shim's first. shim's made a very noticable diffrence.
The new bush for the front arm is very stiff.
Post Posted: Sat May 01, 2010 10:22 am
hang on, do you mean same bush's as the front 2???
Don't think so.
Post Posted: Sat May 01, 2010 11:57 am
no
Post Posted: Sat May 01, 2010 12:10 pm
no
I tink the chassis side's of them are the same, will have a look at part no's on tuesday.
Users browsing this forum: Google Adsense [Bot] and 248 guests
