It is currently Tue Jul 28, 2026 1:52 pm
Post Posted: Sat May 22, 2010 9:45 am
how do you get your gearbox in with a welded crossmember, i really dont want to pull the engine out??
Post Posted: Sat May 22, 2010 9:48 am
got the exact same problem i managed to get it out but after 3 hrs i cant get it back in
Post Posted: Sat May 22, 2010 9:49 am
Grinder :twisted: :twisted:
how did you get it out?
Post Posted: Sat May 22, 2010 9:52 am
by taking the clutch plate off but thats not very handy when the new clutch is in
Post Posted: Sat May 22, 2010 9:57 am
what is it? lada niva, sierra, vitara, GV, jimny, hilux, pootrol?
Post Posted: Sat May 22, 2010 10:00 am
guessing its a sierra, vits they come out
Post Posted: Sat May 22, 2010 10:01 am
haha....takes me 30 minutes in and out.
use your brains kids. take the g/box mount off. having someone who can 'tilt' the engine for you is handy. basically, feed the rear of the box over the c/member, rotate the gearbox a little (clockwise from memory), get someone to tilt the motor if need be and slide forwards.........simple.
Post Posted: Sat May 22, 2010 10:03 am
yes but what about the car 8O
Post Posted: Sat May 22, 2010 10:06 am
wt sierra g13a dident think about tilting the engine forward thx
Post Posted: Sat May 22, 2010 10:12 am
ive done it afew times now and its a prick of a job. its alot easier if you can get a helper. The way i do it is:
Remove the rear mount completely and have the gear stick out with a rag in the hole. (sorry to state the obvious)
Then i put the rear of the box in over the cross member as far as i can get it with the front of the box pointing towards the driver side wheel.
Then with alot of cursing and twisting and trying different angles etc, the box slips in. This can take abit of time to get it to work so 2 people makes it easier to share the work.
It can also help sometimes to have someone pull on the front of the motor as it will be hanging back abit on the mounts.
Then its just a matter of sliding in onto the clutch (which you have already made sure is lined up with the flywheel etc). Its handy to have a length of wood or something to help hold the box up.
I dont know if all Sierras have it but mine has a spacer plate thing that goes between the motor and gear box. Dont do what i did and forget about it till the end and have to separate everything to make it fit!
Thats how ive got it to work.
Tell me how ya go!
Post Posted: Sat May 22, 2010 10:19 am
well this has answered my post to at least i know im not the only one having trouble will have another crack tommorrow any one know how much oil the box takes(sorry about the hijack)
Post Posted: Sat May 22, 2010 10:29 am
45 on the ground.. :P
Post Posted: Sat May 22, 2010 10:37 am
hi, Where in Ipswich are you? Transfer case takes 0.8Ltr of oil according to manual.
Hey give me a call I can offer some advice on getting Gearbox in or out a bit quicker.
David
0409060004
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Sat May 22, 2010 10:46 am
Suzi store have abit of info on their site about how much oil etc.
They say 1.3ltrs for the gearbox but i dont know how accurate it is.
http://www.suzistore.com.au/shopcontent ... edata/SJ70
Post Posted: Sat May 22, 2010 10:54 am
The first time I did a clutch it took me ages then I worked out it is all in the rotation of the box You spin it around on it's side. :wink:
98 GV
Users browsing this forum: No registered users and 324 guests
