It is currently Fri Oct 30, 2026 7:36 pm
Post Posted: Fri Sep 10, 2010 8:43 pm
Mrs Zukenutter has broken something in her gearbox, I thought it was the diff but now upon further inspection is the gearbox.
Her Jimny is a late 2006 VVT with push button 4WD with about 50,000km
when putting drive through the gearbox at idle speed you can hear a click, click, click noise and when you pick up the speed it gets louder until you hear a loud metallic bang/clunk.
Points I've noticed;
- Does it in every gear
- The faster the rear wheels spin the louder and more violent the noise is
- Listening with a screwdriver to the ear the noise seems to be louder at the rear output of the box
- There's definitely no faulty 4WD engaging type issues. The front shaft is definitely stationary
- My hopeful thoughts are that maybe it's the output bearing
Will probably need a gearbox professional, any suggestions in Brisbane North. Gearboxes are something of virgin territory for me.
Post Posted: Fri Sep 10, 2010 9:08 pm
jackshaft uni?
can you wobble the jackshaft in the gearbox?
Post Posted: Fri Sep 10, 2010 11:42 pm
Paul, take it to Diff and Gearbox in 2/280 Newmarket Rd, Wilston. Tell them you know me and they will look after you.
Post Posted: Wed Sep 15, 2010 12:38 am
Gearbox has been removed and stripped. turns out to be main output shaft bearing and with the gears flopping about two gears have been damaged.
So it's either find a 2nd hand box to suit it in a hurry or rebuild with genuine parts for $2200. Bugger!! Money to nothing, could have gotten Air lockers F&R.
Does anybody know if all M series have the same gearbox/ratios or are the VVT models different?
Post Posted: Wed Sep 15, 2010 1:19 am
They should be the same. Even without vvt..
Post Posted: Wed Sep 15, 2010 6:43 am
X2, I have looked it up before & from memory the G/box's are the same..
Can I have the old box???? :P
Post Posted: Wed Sep 15, 2010 6:57 am
If they're all the same the old one will be spares for me... just in case :roll:
Post Posted: Wed Sep 15, 2010 7:03 am
8O But that's not the answer I wanted.... :cry:
Post Posted: Wed Sep 15, 2010 8:27 am
and you got in before me! :( :lol:
If its hard to get one, would the guts from a Sierra 5 speed fit inside?
Apparantly the rear housings are interchageable Here , so does anyone just how much is the same?
Clearance Hole Technology :P
Post Posted: Wed Sep 15, 2010 10:18 am
Here's some pics of the disassembled and beautifully cleaned gearbox case for those who are interested. Also a pic of the damaged gears. I forgot to get a pic of the failed bearing but was just the inner and outer rings.
Post Posted: Wed Sep 15, 2010 11:19 am
wow that is clean!
Users browsing this forum: Google [Bot] and 115 guests
