It is currently Tue Nov 03, 2026 1:23 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Post Posted: Tue Nov 16, 2010 9:56 am
Took the drive shaft off to repair something and when we put it back on it won't engage 4wd.
Working on it right now...and hints?
It's got vacuum operated hubs.
09 Jimny Sierra Limited Edition
Post Posted: Tue Nov 16, 2010 9:57 am
It was working when we took it off.
Post Posted: Tue Nov 16, 2010 9:58 am
The transfer case sounds like it's doing it's thing.
Post Posted: Tue Nov 16, 2010 10:04 am
Could it be the way we have lined it up?
Bloody annoying!!
Post Posted: Tue Nov 16, 2010 10:05 am
don't they have an earth wire or some other wire that hangs down low? that hasn't been knocked/damaged?
Post Posted: Tue Nov 16, 2010 10:10 am
Yeah they do...that has failed in the past and it appears ok.
Post Posted: Tue Nov 16, 2010 10:11 am
3 posts in 3 minutes and another post 6 minutes later... there is an 'edit' button you know?
1988 Suzuki Sierra (SJ50)
1.6L G16A (EFI) with Su
Post Posted: Tue Nov 16, 2010 10:13 am
It was working fine when my mate was removing the driveshaft and now after putting it back on it doesn't.
We can feel it Engaging the shaft, but te hubs are not locking.
It's booked into Suzuki on Thurs so maybe they can figure it out as we are completely stumped.
I'm not on a PC so it's easier to just re-post.
Post Posted: Tue Nov 16, 2010 10:14 am
sell it.... sure it's not related to the long weight?
Post Posted: Tue Nov 16, 2010 10:15 am
Long weight?
Post Posted: Tue Nov 16, 2010 10:58 am
its a problem with the vacum hubs. its been covered hear heaps of times before.
check this out
http://www.bigjimny.com/images/document ... system.pdf
or just do yourself a favour and fit manual hubs.
Post Posted: Tue Nov 16, 2010 11:22 am
It appears as if one of the solenoids is damaged after all and is causing it to leak transfer case oil.
It has hit the cat on my exhaust as we towed the car home behind my Friends cruiser.
This will be the 2nd time I have replaced this part.
Post Posted: Tue Nov 16, 2010 11:25 am
vermin wrote:
Long weight?
Sorry I've made you wait so long for you long weight.... :wink:
Would it be related to the long wait for parts after the bingle?
Post Posted: Tue Nov 16, 2010 11:39 am
It was working off road on Sat, but we didn't fully secure the t/case and now it looks like I am paying the price.
At least we hope that's the problem.
Post Posted: Tue Nov 16, 2010 12:11 pm
hmm manual hub time?
vac hubs are so nice though! i love not having to get out of the car!
Post Posted: Tue Nov 16, 2010 5:08 pm
Check wire coming out of transfer case, had the same problem
Post Posted: Tue Nov 16, 2010 7:46 pm
u gotta get out to air down anyway so just lock he hubs in then.
Post Posted: Tue Nov 16, 2010 7:55 pm
Have you tried moving the car a lil bit??
It selects useing an electric lil motor, if the gear's are not lined up it give's up just to piss you off..
Post Posted: Tue Nov 16, 2010 9:54 pm
Yeah we tried moving the car back and forward...also drive around it a bit.
This solenoid that I replaced already is leaking oil and the cap covering it has mostly sheered off from an impact on my cat (exhaust).
I am sure this is what it must be...otherwise it's off to a Suzuki specialist for further investigation.
Post Posted: Tue Nov 16, 2010 10:01 pm
This is the part I am talking about.
Post Posted: Wed Nov 17, 2010 12:58 am
Thats exactly what happen to mine, suzuki charged $180 to replace it and that was under warranty!! They stated that it wasn't "natural causes", "what?, to a critical wire not protected by a bash plate?", I keep the damaged one in my garage to whinge to ppl about my little experience. F*#kin electronic cases!!
Post Posted: Wed Nov 17, 2010 1:37 am
+1
another reason why I bought my Jimny with a manual trasfer... I dnt trust in push buttons :wink:
Post Posted: Wed Nov 17, 2010 2:12 am
+1
x2
Post Posted: Wed Nov 17, 2010 6:05 am
Good thinking!!! :P
Post Posted: Wed Nov 17, 2010 8:52 am
i got a manual transfer as well, also put manual hubs on casue mine bugged up. been workin fine ever scince :)
Post Posted: Thu Nov 18, 2010 5:53 am
Yup Suzuki can confirm that my solenoid is again damaged!
Got my gearbox seal replaced under warranty and it's off to Suzistore on Mon for a service and to replace the solenoid.
Post Posted: Thu Nov 18, 2010 6:21 am
Got my gearbox seal replaced under warranty and it's off to Suzistore on Mon for a service and to replace the transfer with a stick opperated one!!
:P Good thinking!!!! :P
Post Posted: Thu Nov 18, 2010 8:32 am
Out of interest what's the cost and work involved with doing that?
Post Posted: Thu Nov 18, 2010 8:34 am
From what i have read ya just need the tranfer case and to cut a hole in your floor to do it
Post Posted: Thu Nov 18, 2010 8:36 am
& it's already marked out!!!! :P
Users browsing this forum: Google [Bot] and 571 guests
