It is currently Fri Jul 31, 2026 1:08 am
Post Posted: Mon Jan 17, 2011 12:04 am
I have a mill/drill which takes MT3 arbor. I have a 13mm Jacobs keyless chuck (decent one) which I put a holesaw arbor in as I was using a 54mm holesaw. So I drilled my holes no dramas, but when I came to undo the chuck, the bastard thing was TIGHT.
Short of going at it with multigrips :oops: how the hell do I get the bastard thing undone???? :x
Post Posted: Mon Jan 17, 2011 12:07 am
I remember learning how to do it at school, but it was a long time ago :), maybe punch it loose with a drift?
Post Posted: Mon Jan 17, 2011 12:19 am
I can get the chuck out of the mill (give the drawbar a whack), i just cant undo the chuck so I can get the holesaw out.
Vehicle: 94 Vitara LWB G16b
Post Posted: Mon Jan 17, 2011 12:30 am
if you can get the chuck off, can you use a vice + mutli grip/vice grip?
94 Vitara LWB G16b
Post Posted: Mon Jan 17, 2011 12:37 am
I could, but I don't want to mess up my chuck using multigrips on it!!!
Maybe some alloy or copper shim wrapped around it would protect it?
Post Posted: Mon Jan 17, 2011 12:50 am
it's gonna look bad in 5 years time anyways... :p you could try a cloth... or search you tube....there are tips on ones with keys...couldnt see anything for keyless...bit of a silly idea IMO except on a hand drill
94 Vitara LWB G16b
Post Posted: Mon Jan 17, 2011 12:51 am
alloy or copper and vice/vicegrips/stilson/pipe jaws/hammer/bin
I HATE keyless chucks for that reason.
oops I missed the keyless part, chisel into teh side :)
Post Posted: Mon Jan 17, 2011 12:59 am
I have a feeling these chucks tighten as you use them, and the leverage a holesaw gives is why it is SO tight.
Oops :oops:
Post Posted: Mon Jan 17, 2011 1:00 am
They only get worse as the get older too..
Post Posted: Mon Jan 17, 2011 1:26 am
Did some more Googling, aparantly the way to go is hold it in a vice with soft jaws, then use a strap wrench to undo.
WTF is a strap wrench, yeah, I asked the same thing.
Will have a crack tonight, I think I have some aluminium scrap to use as soft jaws, i'll try to cobble together a strap wrench from old seatbelt material.
I hope it works coz that Jacobs chuck (precision model) won't be cheap to replace!
Post Posted: Mon Jan 17, 2011 1:30 am
Bout $75
https://www.machineryhouse.com.au/Produ ... kCode=C289
Post Posted: Mon Jan 17, 2011 1:54 am
Try an oil filter strap if you have it.
A decent keyless chuck actually has a couple of holes that you can use a C spanner to tighten or loosen the thing.
Post Posted: Mon Jan 17, 2011 2:00 am
I don't remember seeing c spanner holes but i'll have another look tonight.
I was pretty sure ball would post in here and was expecting the first words of balls post to be "you f*cking idiot" :lol:
Post Posted: Mon Jan 17, 2011 2:07 am
nope, I do that shit all the time. The difference is I know I have a spanner to undo the bastard. :wink:
I don't know how hard your chuck is but you may be able to drill some holes in the side like these ones.
Post Posted: Mon Jan 17, 2011 5:43 am
D-Clamp? thats how i get holesaws out of the drill when they get stuck at work...
doesn't mess the chuck up either :)
Stocker
Post Posted: Mon Jan 17, 2011 5:46 am
What's a D-clamp? never come across one of them
Post Posted: Mon Jan 17, 2011 5:49 am
Thats a d Clamp :)
Stocker
Post Posted: Mon Jan 17, 2011 5:54 am
G
Vehicle: 105 landcruiser
Post Posted: Mon Jan 17, 2011 6:22 am
dude dont use multi grips ..just a 3 inch g clamp.. a lot less brutal on the knurled surface . one of my fkn apprentices put a vice grip on mine.. i near killed him. and still might
Post Posted: Mon Jan 17, 2011 6:27 am
Seems like this is a fairly common thing, I don't feel like such a dickhead now :lol:
Thanks for the tips guys.
Post Posted: Mon Jan 17, 2011 6:37 am
ah my bad, g clamp :D ... its a fitting tool. im an electrician :D... forgive the stupidness we work with our hands in the air :D
Stocker
Vehicle: LJ20 LJ50
Post Posted: Mon Jan 17, 2011 7:58 am
I destroyed one with a grinder to get a drill bit out.
$30 ozito drill that burnt out and had a good 12.5mm drill bit in it so I cut the thing open with a cut off wheel
Camels have nice toes
Vehicle: LJ20 LJ50
Post Posted: Mon Jan 17, 2011 8:05 am
since you have a mill drill just machine some flats in it
Post Posted: Mon Jan 17, 2011 8:33 am
Maybe some heat could help..
Post Posted: Mon Jan 17, 2011 8:40 am
flog it with a big hammer until it comes out.
Post Posted: Mon Jan 17, 2011 8:51 am
Yeah that should generate some heat :lol:
Vehicle: Daisy
Post Posted: Mon Jan 17, 2011 9:14 am
Was going to suggest the strap/strap wrench.
Post Posted: Mon Jan 17, 2011 9:18 am
Post Posted: Mon Jan 17, 2011 10:31 am
i just use multi grips on mine at work, and put the drill in reverse... but i'm not overly attached to it :wink:
Go Hard, Trailer Home
Users browsing this forum: No registered users and 307 guests
