It is currently Wed Jul 15, 2026 4:28 am
Post Posted: Wed Mar 02, 2011 6:51 am
as above. for front and rear. what you got.
Post Posted: Wed Mar 02, 2011 6:57 am
I have a 4.6 front diff here. Removed from SV420.
$150 for complete diff centre.
Vehicle: 98 Maruti
Post Posted: Wed Mar 02, 2011 7:14 am
i have a pair of stock GV diffs
sorry not sure if they are 4.8s or not
Post Posted: Wed Mar 02, 2011 7:37 am
doesn't the GV already have 4.6's or 4.8's fitted standard?
Post Posted: Wed Mar 02, 2011 7:53 am
Standard is 4.3 manual and 4.8 auto...thats the v6, not sure about the 4cyl.
B4T has a manual.
My Grand Vitara
Post Posted: Wed Mar 02, 2011 8:06 am
B4T has a manual.
well i learned something new today.
Post Posted: Wed Mar 02, 2011 8:10 am
I have a 4.6 rear here.... in an 89 auto SWB vit.
Post Posted: Wed Mar 02, 2011 8:21 am
What did they come out of?
2.5 V6 - defiantly 4.3, I have a front R & P with center left over out of mine.
If your not breaking shit, try harder!!!
Post Posted: Wed Mar 02, 2011 8:32 am
to clarafy things a bit.
early 1.6swb GV's had 5.12
2.0l man gv = 4.8
2.0l auto GV = 5.12
2.5 V6 man = 4.3
2.5 V6 auto = 4.8.
Mine is a 2.5 V6 manual and im trying to correct gearng lost from fitting bigger tyres. Vit 4.6 gears will get it right but if i go up one more size they will be out again. so i'd really like some 4.8's.
I will swap the 5.12 gears ive got if you want to re-gear your GV.
Cheers.
Last edited by Built4thrashing on Wed Mar 02, 2011 8:55 am, edited 1 time in total.
Post Posted: Wed Mar 02, 2011 8:42 am
B4T has a manual.
You're welcome :wink: :helloo:
My Grand Vitara
Post Posted: Wed Mar 02, 2011 8:56 am
Sorry I mis-interpreted you post.
So you want a front and rear 4.6 ratio diff to fit to a GV....
I have a matching pair here from the SV wreck. I have not removed the rear to inspect, but iw was not noisy at all, so I would assume its good. Probably a 12 bolt though.
Post Posted: Wed Mar 02, 2011 9:16 am
Front needs to be 10 bolt. not sure on the rear but i assume its the same. (10bolt)
Post Posted: Wed Mar 02, 2011 9:19 am
All fronts are 10 bolts aren't the?
Vehicle: 2004 SQ625 GV
Post Posted: Wed Mar 02, 2011 9:40 am
GV's have 10 bolt front and 12 bolt rears. The SV rear diff from Ninjamoses SV was 12 also. So the 4.6's should go straight onto the GV centers
Post Posted: Wed Mar 02, 2011 2:04 pm
If you are wanting the complete centres I can't help, but I've got a front and rear set of 4.6 R&Ps out of my SV if you are interested? Not sure how much they'd be worth, say $250 for both?
Front is 10 bolt, rear is 12.
Moses' SQ625 GV Pig
Post Posted: Thu Mar 03, 2011 6:18 am
I though only the early model 3spd autos had 4.625 R&P ratios :?
Ninja yours is manual yeah?
My Grand Vitara
Post Posted: Thu Mar 03, 2011 6:23 am
You'de be wrong :wink:
1.6 4sp auto, 2.0 man J20, 2.0 H20 man all 4.6 ratios. Auto SV's may also be 4.6?
Post Posted: Thu Mar 03, 2011 6:27 am
Would that mean that they all 10 bolt front and 12 bolt rear aswell? if so straight swap into GV diffs?
Sorry not meaning to hijack....just learning stuff :)
My Grand Vitara
Post Posted: Thu Mar 03, 2011 7:02 am
This is good to know as im starting to seach for what i need. 4.6 vit gears seem easier to find then 4.8 GV gears. when i do the swap ill be putting a lockright in the rear.
Post Posted: Thu Mar 03, 2011 7:07 am
I'm prettysure all of the SE416's were 10 bolt rears. I think the SV series were the first 12 bolt rears. Could be wrong though :?
Post Posted: Thu Mar 03, 2011 7:30 am
Joe wrote:
Mid 94 onwards they changed to 12 bolt
Vehicle: Zookless
Post Posted: Fri Mar 18, 2011 8:20 am
I've got some X90 4.875:1 diffs.
If the R&P's will fit I'll pull them out for you. :)
Vehicle: 02 GV SQ625 + 84 Sierra SJ410
Post Posted: Tue Apr 05, 2011 3:42 am
I'm after 5.12 steel diff centres (front and back) for my 02 Manual V6 GV.
If anyone has any to sell or knows where to get some please PM.
