It is currently Wed Nov 04, 2026 9:41 pm
Post Posted: Sat Mar 12, 2011 12:51 am
Hey guys just bought a lwb zook it has a holley/webber 180 i think it is not sure weither to rebuild that or i have to stanard 1.3 carby wich is better. As i do alot of highway driving and beach and bush 4wding..
Need your help guys cheers joel
Post Posted: Sat Mar 12, 2011 12:54 am
people with webbers have had problems on steep inclines.
But if its used lots on highway and beach (where there's no angles) then I would keep the webber. It will give better on road performance
My Rig --> Click WWW
Vehicle: Vitara
Post Posted: Sat Mar 12, 2011 12:56 am
Webbers dont tend to like hills moreso then most other carbies.
stock carbies are pretty well matched to the motor but lack oomf but will allow you to run a snorkel easier and i think you will get better fuel economy from a stock one.(someone correct me if i'm wrong)
but, I'd personally go the Holley 180 (I have one in the box new waiting to go on :D) more go to them and they can handle hills better then the webber 32/36 I have..
Ron
Repping it, High Top style!
Post Posted: Sat Mar 12, 2011 12:58 am
ok cause atm its flooding on level ground and leaking fuel everywhere i went a bought a 1.3 carby today but still not sure cuase this one needs a kit put through it aswell.
Post Posted: Sat Mar 12, 2011 1:07 am
can you post a pic of your holley please
Vehicle: Vitara
Post Posted: Sat Mar 12, 2011 1:08 am
well since youve already got the webber, check out what the price difference in rebuild kits are. Chances are the 1.3 carby could have more wrong with it then the (newer?) Webber and the rebuild kits From what i looked at were easier to get, some stores stock the webber rebuild kits on the shelf..
Post Posted: Sat Mar 12, 2011 1:22 am
Post Posted: Sat Mar 12, 2011 1:52 am
ok well ill look into getting the webber fixed as i have the extractors and 2 inch now the carby has holley stamped in the side does that matter?
Post Posted: Sat Mar 12, 2011 1:59 am
I forgot to mention its running a electric fuel pump will that matter
Post Posted: Sat Mar 12, 2011 2:29 am
only if it doesnt have a pressure reg... webers like around 4psi from memory (my memory is wayyy fuzzy so thats not gospel)
Vehicle: Vitara
Post Posted: Sat Mar 12, 2011 2:36 am
Its not a webber then?. Holley and Webber are 2 different makers..
Post Posted: Sat Mar 12, 2011 3:03 am
The 32/36 webber, and the 180 holley are basically identical.
Shakes is right, 4psi max.
Post Posted: Sun Mar 13, 2011 5:20 am
Hi All, Are Webbers on 1.3lt Sierra's street legal in NSW please - IE will they pass a BLUE slip inspection?
Tony
Users browsing this forum: Google [Bot] and 204 guests
