It is currently Wed Jul 29, 2026 10:37 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
Post Posted: Fri Aug 05, 2011 6:28 pm
I need some good ideas for an tray
i know it would look better with he axle placed backwards
but that`s going to give lots of trouble to keep it road legal
anyone?!
pic's?
other advice or comments is always welcome
Post Posted: Fri Aug 05, 2011 7:01 pm
Don't matter wat u do it's still going to look stupid with a 3 foot tray
Coil the rear end then u can drag the diff back with out a chassis extention
Fliped controll arms in the original spring hanger might work
Then all u need is coil seat and a panhard rod and shock mounts
Post Posted: Fri Aug 05, 2011 7:12 pm
the big problem is that over here extending the wheelbase is an no-go
and it would not pass any MOT :evil:
damn i wish lwb sammy's werent so rare over here
Post Posted: Fri Aug 05, 2011 7:46 pm
It's not an extension of the chassis. You welded in some new sections to repair chassis damage, bugger....I cut them a little to long :twisted:
Post Posted: Fri Aug 05, 2011 11:49 pm
There not allowed to change the chassis in any way or the car is never to be registered again
The bits 4 vits gv had the back bobed of and then he could never get it passed
Are u sure u can't extend the wb if u don't change the frame only add to the inside of it
It's all to do with rear crash rules or something like that isn't it
Post Posted: Sat Aug 06, 2011 11:45 am
the wheelbase is registerd on the papers
and checked every MOT
maybe its possible to extend it
but it will be a long road
it has to be checked out totaly to get a new register
and then there gone bug about the spoa the engine the winch and all the other shit that makes it a good 4wd
and then after all the blood and tairs the are going to tell me that its never gonna happen
so then i lost a lot of money and still havent got MOT
meantime i'm looking out for an lwb chassis but there hard to come by over here
Post Posted: Sat Aug 06, 2011 2:02 pm
just put a flat tray on to cover it up then... no point trying to polish a turd =) just drive it!
Post Posted: Sat Aug 06, 2011 10:53 pm
Maybe try to find an ID plate from a LWB, that could be easier to find.
Vehicle: Daisy
Post Posted: Sat Aug 06, 2011 11:08 pm
Was thinking what about some kind of toolbox type tray? Depending on what you use it for.
Explaining what I mean, basically almost a flat trayback, but a couple of hundred mm deep and the lid on gas struts so you can put crap in it or on top of it.
I suppose it depends if you're going to cage it or not though.
Post Posted: Sun Aug 07, 2011 12:41 am
http://forum.difflock.com/viewtopic.php ... d9aea4d9a2
Its hard to tell but I think the axle may have been moved back a touch, but the look of the cage it self is alright.
Post Posted: Sun Aug 07, 2011 12:53 am
^ That looks like it has a double B pillar! Good for a spacecab.
If your able to weld onto the chassis, 3link+panhard the rear, link it for standard length wheelbase, and make longer arms, tailshaft for a longer wheel base setup. So that also means 4 rear top coilmounts. and 2 panhard mounts.. Makes things easier to swap for mot. But i guess they would pick on the welding too..
I watched a show a while ago on tv, looks like they are getting picky everywhere. Even russia, where the cars fall apart, so many trucks and cars failed and many old people were complaining.
Post Posted: Sun Aug 07, 2011 1:58 pm
Red89 wrote:
http://forum.difflock.com/viewtopic.php?t=47840&sid=e21fd9c3ee1c9e7f02d2d8d9aea4d9a2
i now this one for a while
and the first plan was to build somthing like it
it has an vitara/tracker axle with coils under it
so its a inch or 3/4 longer
but then i came along matt's lwb and fell in love :evil:
http://www.auszookers.com/index.php?nam ... k&start=30
it's just something nobody around here has got 8)
Post Posted: Fri Oct 07, 2011 7:27 pm
started on the tray
so the turd is coming back to live :wink:
plan is to make a short tray for the challenge i'm gonna drive in
so it's nice and tight between all the l#ndr#v#r shit driving there
not done yet so there's no sign of any bracing yet
but there's gonna be plenty of that in time
Post Posted: Fri Oct 07, 2011 9:54 pm
Why so high? Putting anything on the tray will now be pointless as the COG will be so much higher making it more prone to rolling.
Why did you cut the back off in the first place, was there a reason?
Post Posted: Sat Oct 08, 2011 5:52 pm
because it was really rotten mate
there was no metal left to weld anything on
why so high? any lower and it would really look like shit
there's gonna be a box in between the bars so al the weight is low
oh by the way, i'm pretty long :)
Post Posted: Sat Oct 08, 2011 8:37 pm
Thats a fair enough reason, I was only asking to find out what sort of tray you were going for. Eg: if you chopped it because you are going to use it in competitions, then storage isnt really neccessary, however if you chopped it because you were hoping to store more crap, then you would need a very useable tray.
I still think lower it so that it matches the height of the front guards, but thats just my opinion. Best of luck with it!
Post Posted: Sat Oct 08, 2011 9:42 pm
That green thing would have to be one of the first cut down ute conversions that actually looks alright. They have made the body/tray flow.
Post Posted: Sat Oct 08, 2011 10:52 pm
shakes wrote:
That green thing would have to be the only cut down ute conversion that actually looks alright. They have made the body/tray flow.
It's a shame that more aren't built that well. It's not really a chop though (as in a trayback conversion) it's more of a tubed out tub.
It would be interesting to see what it looks like now though - it reckon there would be some funky flexing/stress going on between the stock panels and the tube rear. I reckon it would be a prime candidate to crack around the transition. Sierra bodies move a lot on the chassis and my guess is the tube won't be moving at all relative to the chassis.
Post Posted: Tue Oct 11, 2011 3:25 pm
i never heard of the green sj again and its an pretty old topic
it maybe dead in the line off duty
it sure would be crackt if its still alive
@brenno:its going to compete next year in the www.noordelijke4wdchallenge.nl in an field of all l@ndr@vers.
so there is no need for big storage only some recovery materials
highjack groundanckor and that kind off stuff
unlike the lr i want it to be light, short and small
so i can drive where they get stuck :)
Post Posted: Fri Oct 28, 2011 7:40 pm
Vehicle: SJ51T
Post Posted: Fri Oct 28, 2011 8:19 pm
Trays looking good Brammie.
When you posted those videos of you in schuilenburg, you dont live near there do you? only ask because i was in Hellendoorn only a few weeks ago.
Post Posted: Sat Oct 29, 2011 4:15 pm
i live only a 30 min drive from schuilenburg
hellendoorn is about 3 hours
nice wether in holland aint it? :evil:
its been raining all summer over here
only advantage is that the mud is coming soon
in a hole near you 8)
Vehicle: SJ51T
Post Posted: Sat Oct 29, 2011 7:02 pm
haha yeah i was given the heads up a few weeks before i got there so it didnt bother me to much. plus i love The netherlands. If i was to move to europe, i'd move there.
Post Posted: Sat Oct 29, 2011 8:25 pm
ow man don't even think of moving over here
don't get me wrong, your welcome
but think twice of all the bloody rain and cold shit we get over here
if i got to move somewere i would go to your side
hmm i feel a switch coming up :wink:
coverments are all the same so your screwed no matter were you life
Post Posted: Thu Nov 17, 2011 2:37 pm
a bit more done
now for de time comsuming rest of it
Post Posted: Sat Nov 26, 2011 10:29 am
Post Posted: Sun Nov 27, 2011 8:24 am
looks good bud, nice work.
Post Posted: Sun Dec 11, 2011 5:49 pm
it's black
Image[/quote]
Post Posted: Mon Feb 06, 2012 5:03 am
it's got MOT :D
just finishing the last things
Post Posted: Mon Feb 06, 2012 8:39 am
Looking good Brammie.
Users browsing this forum: Google [Bot] and 363 guests
