It is currently Mon Jun 08, 2026 4:32 pm
Vehicle: Suzuki sierra
Post Posted: Tue Jul 03, 2012 3:48 pm
I'm changing my sump gasket and I'm wondering whats the best sealant to use
Post Posted: Tue Jul 03, 2012 6:03 pm
Image Image
Post Posted: Tue Jul 03, 2012 8:09 pm
How hard is it to change a sump gasket.do you put the sealant both sides of the gasket.
Post Posted: Tue Jul 03, 2012 8:12 pm
there is no gasket used on suzuki sumps only the sealant...
clean both surfaces so they're spotless, apply a bead around one of the flanges (engine or sump) & around the bolt holes, let it tack off slightly, then refit the sump.
Post Posted: Tue Jul 03, 2012 8:18 pm
Why do they sell the gasket then
Post Posted: Tue Jul 03, 2012 8:33 pm
there is a cork gasket available for 8 valve engines
Post Posted: Tue Jul 03, 2012 8:44 pm
sorry boss, didn't realise that there was one for the 8 valve, i was recalling this post of losfers & his hate of cork gaskets...
losfer wrote:
on a side note , i absolutely hate cork gaskets , i prefer a high temp rtv silicone myself , i am that confident , that i would use a silicone , let it cure , then remove all the bolts and drive around .
most suzukis left the factory with silicone
(3 bond) as a sump gasket. when you go to remove the sump from the engine it takes quite some force.
the only time i will ever use a cork gasket is in a "in car situation" where theres a possibility of scraping some of the silicon on something else and compromising the seal , in this case i will use a cork gasket that is glued to the sump using contact adhesive , you should never use a silicon sealant with a cork gasket.
Post Posted: Tue Jul 03, 2012 8:50 pm
Can ya get away with one for a 1.3l serria.by the way I know this might be a silly question but what do you mean bead.
Post Posted: Tue Jul 03, 2012 8:51 pm
when you squeeze the tube & the stuff comes out like a worm... that's a bead. :wink:
Vehicle: 4wd
Post Posted: Tue Jul 03, 2012 9:13 pm
Suzi Store list a cork gasket for the 16v engine, but when ordered they send a 8v gasket :roll:
Watch out or you'll get sued.
Post Posted: Wed Jul 04, 2012 4:12 am
Can I get away with just putting the sealant on.some people say you don't need the gasket.
Post Posted: Wed Jul 04, 2012 4:17 am
Yesss
Post Posted: Wed Jul 04, 2012 4:37 am
No worries thanks mate
Post Posted: Wed Jul 04, 2012 4:57 am
Can you also smear the sealant around the sump or you have to do that bead apply.
Post Posted: Wed Jul 04, 2012 12:33 pm
Has to be enough so when you bolt the sump on, the silicone squishes and seals a good amount on both sides.
Both sides must be clean of oil.
Most of my oil gaskets go in the bin to run silicone only.
Vehicle: On the lookout
Post Posted: Wed Jul 04, 2012 3:03 pm
This threads kinda been talked to death already, but I can vouch for the Locktite product pictured above and comes with clear instructions on how to apply.
Crispy old grand vitara
Post Posted: Thu Jul 05, 2012 1:12 am
I rebuilt a 202 Holden Red motor once. Someone had used silicone instead of the cork gasket for the sump, bits of silicone had separated off and partially blocked the oil pickup. The bearings were nicely down to the copper.
I like cork.
Cork you idiot, not cock. :thefinger:
Post Posted: Thu Jul 05, 2012 3:44 am
A mates 253 had the same issue with the silicon.
But for a Sierra motor it works just fine.
Vehicle: Yellow Ute
Post Posted: Thu Jul 05, 2012 12:04 pm
I like cork.
Seen the same in a mates hilux motor
The problem is people must think they need to use the whole tube for a thermostat housing. :deadhorse:
Post Posted: Sat Jul 07, 2012 7:50 am
No the problem is that there are numerous silicone sealants but not all are designed to be used where oil is in play, if you use the correct one you will not have this problem.
Post Posted: Sat Jul 07, 2012 9:45 am
Could you tell us the right one to use mate.
Post Posted: Sat Jul 07, 2012 9:50 am
want33s wrote:
Image Image
:roll:
Post Posted: Sat Jul 07, 2012 9:52 am
And these are the ones where oil is in play
Post Posted: Sat Jul 07, 2012 9:55 am
Sorry I mean and these sealants good for what 2strocker commented before
Post Posted: Sat Jul 07, 2012 9:57 am
It says on the packet on the right.."OUTSTANDING OIL RESISTANCE". 8O :roll: 8O
Do you really think I'd recommend you use an unsuitable product?
Post Posted: Sat Jul 07, 2012 10:01 am
No sorry mate.thanks for that
Post Posted: Tue Jul 10, 2012 1:49 pm
I know you can glue the gasket to what's good glue to use
Post Posted: Tue Jul 10, 2012 1:56 pm
Seriously, are you retarded? USE SOME GODDAMN RTV SILICONE THAT IS OIL RESISTANT!!! :roll:
Post Posted: Tue Jul 10, 2012 3:49 pm
want33s wrote:
Image Image
Post Posted: Tue Jul 10, 2012 4:42 pm
Sorry what i mean is People use a Contact adhesive rather then silicon to glue the gasket on
